Question about IBM ThinkPad A21m 2628 Notebook
Keeps looping into safemode
My Thinkpad keeps looping into Safemode. I've tried System Restore and I've tried disabling all programs in msconfig. Any other suggenstions for a fix?
    Scholar:
  • 135 Answers
When restarting, try pushing F12 until the boot menu comes up and then choose "Last Known Good Configuration" or the Windows XP (or other OS) non-safe mode option.
Posted on Jan 05, 2008
If these good solutions do not work. You could try a Program disk called System Suite and as far back as System Suite 5 should work with Windows XP. It will allow you access to System Restore and the restore data base of the said program if installed and activated. It works in a non-windows environment or DOS. Just put the CD in Reboot if not you will have to go to the Bios and select the CD as the Boot Drive.
Posted on Sep 12, 2008
McAfee page keeps coming on my screen with no way to exit it other than closing my computer down. Please help
go into safemode for windows by pressing F8 repeatedly when the pc starts up.
while in safemode you can either uninstall mcAfee or disable it's start up
to disable its start up goto Start - Run(or search box) - in run type msconfig
when the box pops up click on the Startup tab
unclick anything that say McAfee. Then click on the Services tab
and unclick anything that says McAfee.
click on Ok then reboot
When the pc reboots check on "Don't Show again" in the system changed box
Oct 29, 2013 | Mcafee VirusScan Plus 2009 - 3 User with ...
I turn on the computer and it starts working fine, when the page of Windows starts and all the icons appears it goes off and goes on again like if i restart it and keep doing the it. It's a HP Compaq...
You have mentioned that your computer works in safemode. This means that there are programs that starts up with windows that is causing this problem. In safemode, click start then run. In the run box type msconfig then click ok. At the startup tab you will see the programs that starts up with xp. Try disabling some or all of them (trial and error) to check which software gives you this problem.
Jun 01, 2011 | HP RT935UAABA - HP Compaq dc7800...
Frozen screen
Hi
it may be worth trying this
power up and at the same time keep pressing the F5/F8 key until it takes you into
a black repair option screen
then i would try to use the last good known configuration option
if that dont work then do the same but try the safe mode and when on the desktop
go to device manager scroll down to find the display and uninstall it
then restart and hopefully all should be well
good luck
Mar 06, 2011 | Acer Aspire 5500 5570-2609 Laptop
My laptop has power but wont boot...please help
hi,
Try to boot you computer to safemode, turn off computer then turn it back on then keep on tapping F8, then choose safemode, if youre able to boot to safemode, do system restore going back to the time that its properly working, click start > all programs > accesories> system tools > system restore then pick a date when you think that its properly working..
If its not able to boot to safemode, you will need to reinstall the operating system using the recovery disc that came with the computer.
Hope this will help... Please rate...
Jan 20, 2011 | Acer Computers & Internet
Rebooting loop on advent laptop
See if it will run in safemode tap F8 as it boots - then choose "safemode" - see if that works If it does:-
  1. Try doing a system restore to before the problem started start> programs> accessories> system tools> system restore > choose a date before the problem started
  2. If that does not work, then try doing a clean boot - details here http://support.microsoft.com/kb/331796 Now if it works when booted normally - you will need to go back into the configuration tool and find out which program is causing the issue - reply here if that's the case, and I can work you through the detail
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 01, 2010 | Computers & Internet
I have a Dell Dimension 8400 PC desktop. When I tried to turn it on the fan will start and it will begin to boot but then suddenly stops and the light on the front goes from green to yellow. (Not...
Try going into Safemode. If the system stays on while in safemode, when try disabling start up items.
To go to safemode, press F8 when starting the PC or while you see the Dell logo.
To disable start up items, Click on Start>Run>then type MSCONFIG, then press "Go". IN System Configuration Window, click on Startup tab, then uncheck all the items. You can also use this link as guide.
http://imasters.japancase.com/msconfig/
If the system works find on safemode, or after removing startup items, then you have a software issue. OS reinstallation is easiest approach.
Mar 05, 2010 | Dell Computers & Internet
Medion laptop min2230 will not start up in normal, keeps looping back to menu. OK in safe mode. granddad
1. what changed since you starting having the problem? attempt to do a system restore from safemode and go back to where the problem did not existed. or uninstalled anything that you may suspect is the reason for the problem.
2. I would start with a clean up running updated antivirus and other anti malware programs.
3. use your msconfig tool (start>run>msconfig) and check your startup tab, find what's installed that it's not supposed to be started at start up. (becarefull with this tool, some services and programs are required to so if possible find more info on each entry by googling it before disabling it.
that should be a good start-off on your troubleshooting path.
good luck
Dec 31, 2009 | Computers & Internet
Okay i have an Acer BL50 with vista home on it that keeps shutting down without any warning just a blank black screen and then shutdown and then it restarts itself. I have done troubleshooting scanning in...
well you seem to have a program that restarts your computer, so run msconfig, and disable any program that might seem suspicious, most of the programs dont really affect anything if disabled, or can b reached by start menu. so you can try to disable any suspicious services or programs from msconfig and see if it works. hope it helps. goodluck.
Aug 24, 2009 | Computers & Internet
Start menu keeps flashing on/off,dell laptop.
Hi rayo49,
Try booting in safemode. restart your computer and tap F8 repeatedly at boot up. select safemode and select windows xp.
If it does the same thing in safemode check the windows key on your keyboard. it may be stuck.
If it does not. try using system restore. start>all programs> accessories> system tools> system restore. rsetore computer to a few days back or before the problem begun
Oct 11, 2008 | Dell Inspiron 2650 Notebook
My computer keeps freezing
Try booting into safemode then do system restore.
while in safe mode
start>programs>accessories>system restore
Sep 12, 2008 | Computers & Internet
IBM ThinkPad A21m 2628 Notebook Logo
117 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
