hi. Take the recovery tank out of the cleaner, take off the top. There is a plastic block inserted in the fron of the tank, it slides up, pull it up and out. Take your hose end, the hose end block slides in there in its place.. then you replace your lid, be sure to rollit from the front to the back, feel the "click", reinstall your tank. Now insert the small hose into the receptacle that opens with a hinged flap. I hope this helps to fix ya (haha). Let me know if it does, because your good feedback helps me get good ratings! Thanks! Rene(The Vacuum Doctor) Here is a manual if you need it. http://www.hoover.com/pdfs/manuals/F5906900.pdf
when I use it it leaks out of bottom. when it off an water in tank leaks out of bottom,when its off...
(More)
when I use it it leaks out of bottom. when it off an water in tank leaks out of bottom,when its off an I pull the triggar it flows big time out of bottom. tank doesnt leak when off sitting with water in it
can't find a user manual for a commital sami TR5 steam cleaner. Made in Italy. Cannot put product in...
(More)
can't find a user manual for a commital sami TR5 steam cleaner. Made in Italy. Cannot put product in the product window
