Question about Samsung HLN617W 61" Rear Projection HDTV
Will my lamp still turn on if my color wheel needs replacing? How will I know if it is my color wheel or ballast that needs replacing??
    President:
  • 1,284 Answers
If the color wheel doesn't start rotating or get up to the proper roatation speed then the lamp will never fire.
Posted on Jan 24, 2008
5 Suggested Answers
  • 31 Answers
SOURCE: TV will not turn on, Have three blinking lights, lamp won't turn on, color wheel isnt spinning.
the color wheel wil need to be replaced soon if it is doing that. it could be then DMD board as will.
Posted on Aug 14, 2008
SOURCE: Ballast or Lamp?
my tv is also turning off and the three light keep blinking. the tech came out and changed the lamp and was ready to leave and then the tv started to flickering again. He then said that it was the light engine and it would cost about 1000 dollars to fix. Is it something that I can replace?
Posted on Feb 17, 2009
asnowman
  • 788 Answers
SOURCE: ballast or color wheel next?
The color wheel will normally spin-up even for a brief moment when the set is powered up. I have not seen a color wheel go out with a lamp. I have seen a ballast go bad with a lamp. I would replace the ballast first. You did not state wheather the color wheel was noisy or not. On the Samsung DLP, the color wheel is normally very noisy before it is gone. I hope this will help you.
Posted on Apr 29, 2009
ladywinn
  • 5138 Answers
SOURCE: how to replace the samsung HLN5065 W color wheel.
Be sure to label your wirers when disconnecting, it really is easy to change out the color wheel,thats what I had to do to mine another expert on FY did post How to replace Color Wheel see if you can find it they did an excellent job on that Post.Color wheel is located in front of the Lamp, Pull lamp out and use a flash light you will see it. You will also have to pull the chassis out good enough to be albe to reach color wheel .Good Luck with your Repair.
Posted on Jul 02, 2010
Testimonial: "Appreciate your help link. Unfortunately, my problem didn't stop there but at the main power board at the heart of the set; a big ticket item if you can find one! So I took my lumps and bought a new model. Regards, Mark"
Model WD-65734. Why is there no picture?
Never heard of a color wheel needing to be replaced. Both cooling fans need to be clean and turn easily. Color wheel fan needs to turn easily. If any one of these motors does not turn, the controller will cause a shut-down. The Xenon lamp uses high voltage to operate. If the power supply was damaged, the lamp won't light. The sparking on the ballast board indicates that dirt or dust may be causing the problem. Also, the clamping diodes and regulator may be defective. If possible, try replacing the lamp power board. Regards.
Dec 22, 2015 | Mitsubishi WD Televison & Video
Lamp was replace, color wheel and now ballaster and now the bulb does not turn on.
the only thing I can think of is be sure the safety switch on the back is not your problem.
Mar 12, 2012 | Televison & Video
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Ballast or color wheel next?
Apr 29, 2009 | Televison & Video
I need your help with my DLP TV
YOU PROBABLY NEED A DMD BOARD. THE COST OF THE BOARD IS $900 . YOU CAN GET A LIGHT ENGINE FOR $700 THAT HAS A NEW LAMP, COLOR WHEEL, BALLAST AND DMD.
WHAT A DEAL . THERE IS A $400 CORE ON IT SO YOU WILL HAVE TO SEND BACK YOUR NEW BALLAST AND LAMP TO GET THE CREDIT BACK.
WHEN I GIVE A QUOTE ON THESE SETS FOR REPAIR MOST OF THE TIME IT EXCEEDS THE VALUE OF GETTING A NEWER BETTER SET.
DON.
Jun 04, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
T.v. will not turn on. flahes "lamp" then no picture!
This will have to be narrowed down to a specific problem. I would try the easiest things first. First check the lamp. Is it bad or just starting to go bad or does it just need to be reseated with the ballast? If the ballast flickers when turning on your TV, then you will know it is the lamp that is not working or the ballast may need to be replaced. If that is not the problem next check to see if the color wheel is spinning or broken. If broken, it will need to be replaced. If not spinning it is the DMD board that is bad. The color wheel is plugged into the DMD board. If the DMD board is good it will spin the color wheel, that is what will start your lamp. When you lamp starts, you have your picture.
Mar 23, 2008 | Samsung HL-R6167W 61" HDTV
Samsung LA40R71BD will not turn on stanby button keeps flashing and making a clicking sound.
This could be lamp or ballast. First I would check the lamp. It could be bad (causing the clicking) or it may just need to be reseated with the ballast. If the lamp is not bad make sure it is connected to the ballast and pushed all the way in. If you still hear the clicking (the clicking may be the ballast trying to light the lamp. when turning on your tv, look to see if the ballast is flickering causing the clicking) and your lamp is good and seated correctly, then you ballast is going bad and it needs to be replaced. Last but not least. If that is not the problem then the clicking is a broken color wheel. A broken color wheel will sound like a clicking or a high squeal when going bad.
Mar 23, 2008 | Televison & Video
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HLN617W 61" Rear Projection HDTV Logo
194 people viewed this question
Jerry Greenberg
Jerry Greenberg
