Question about Maytag Neptune Washer
Stops between cycles
I have a maytag neptune mah3000aww washing machine. The machine stops between each cycle. I must push start to get it going again
  • 5 more comments
  • G-Mike Jan 05, 2008
    What's a motor kit?
  • G-Mike Jan 06, 2008
    where can a Part# is12002039-motor conversion kit be found or purchased?
    OK, I ran the motor & Motor control test, and the Motor Phase Test. Both tested fine. ANY MORE SUGGESTIONS?
    Now I've ran the Motor & Motor control test the tested fine. Then I ran a motor windings test. All tested ok. Now I lost as to what to check next, any suggestions?????//
  • G-Mike Jan 08, 2008
    OK people, upon really close inspection with a magnifying glass of the machine control board I think I've found the problem. The Q3 Triac is burnt. Not the Q6 which goes when the R-11 burns but the Q3.
    I plan on replacing this component a see what happens. I'm also presuming it's the same MAC97A6 (400 volt). Some where I read to replace it with the NTE 5657 which is the same but 600volt instead of 400volt.
    I will report on the results, Thanks for you help and continued input!
  • Anonymous Feb 19, 2008
    I have the same problem with my Neptune MAH3000AWW. Purchased 1999. After 6 to 8 weeks of this and it getting worse it is almost as though when the motor stops then tries to start again it just hasn't the power. When I push the start button it tries to start then I hear a "click" then I have to push start again. Sometimes 7 or 8 times before it gets going. Sometimes I have to advance the timer slightly then start it. Is it possible the motor is weak and at heavier loads just can't get going? The door definitely is staying shut and r11 is good. I've cleaned the water inlet screens, even replaced the start/stop switch. It is just getting worse.
    Richard
  • 53Ardy Feb 19, 2008
    I have the same problem with my Neptune MAH3000AWW I bought in 1999 The motor stops in any part of the cycle. The door stays latched. R11 is good. I've cleaned the water inlet screens, and even replaced the start/stop switch. It is just getting worse. It started about 3 months ago. At that time it would do this once in 5 loads. Now you must stay with it at least 3 - 4 times a load and on heavier loads 20-30 times. During the cycle it happens as soon as the motor stops in one direction and tries to start the opposite direction. It is as though the motor just hasn't got the power to take off. Sometimes I have to advance the timer very slightly to get it started other times just repeated depressing the start button and it will finally take off. Is it possible the motor is overheating and tripping a circuit?
    Ardy
    Welcome Back:
    Visited the website for 2 consecutive days.
I had the same problem a year after I installed a new control board. I found the relay on the control board to have a poor solder joint (it cracked in two places). I soldered the relay with additional solder and it has been working fine now.
Posted on Jan 07, 2008
  • 90 Answers
Sounds like a bad motor control board. It is located at the front rt bottom and will probably show a burnt spot in it or the fuse will be blown. You must replace motor kit.
Posted on Jan 05, 2008
  • 1 more comment
  • Douglas Woods Jan 06, 2008
    if that is the problem you have to replace motor and motor control board-Part# is12002039-motor conversion kit
    repairclinic.com
  • Douglas Woods Jan 07, 2008
    Is the door locking
2 Suggested Answers
  • 311 Answers
SOURCE: My maytag neptune MAH3000aww washing won't go into
most common issue with these is the door lock assy. You need to remove the control panel and check the R11 resistor on the board most likely it will be burnt. This was a common issue a few years back. If the R11 resistor is burnt you need to replace the door lock AND control board or your problem will occur again.
Hope this helps _MJ_
Posted on Jan 31, 2010
Neptune washer mah3000aww skips to spin cycle and wont drain
It sounds like the "repaired" main control board is still the issue with it being intermittent.
Nov 20, 2012 | Maytag Neptune Washer
Maytag neptune mah3000aww washer. It cycles then sits at the end of spin, does not go off. then the door will not unlock. I turn to off, push off button. it is anyones guess if it opens
Possible that the door lock is not actuated to open after the end of the cycle and could be jammed. try using a degreasing spray like WD 40 and if there is any issue with the lock.
check this link: door lock
Jul 05, 2012 | Maytag Washing Machines
Maytag washer wiring diagram
machine start when you push the start button but stops 3 or 4 seconds after the button is released help me dennis montgomery maytag neptune model #mah3000aww
Aug 27, 2010 | Maytag MAH8700AWM Neptune Front Load...
Jan 31, 2010 | Maytag Washing Machines
IMaytag neptune washer stops at every cycle
Unplug the washer for 10 min to reboot the curcuit board. This will clear the little brain of any unwanted commands. Selecting too many cycles in a short period of time in frustration can overwelm the little brain. This can also happen with power surges from the electrical company. Undervoltage or overvoltage can cause similar problems. Rebooting clears the memory in the board and starts from scratch.
Apr 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer runs when timer dial turned though ON button not pushed
Problem solved by ourselves! It was NOT in the circuit board (brain) of the machine. It was NOT in the door locking assembly as others would lead us to believe. It WAS the on/off switch on the control panel--part number 22002560 - a $22.00 problem fix.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAH3000AWW Trips 20Amp Breaker at rinse cycle
The motor is known to have bad windings. Do a search for "Neptune Washer will not start" Also just inside the control panel where the start/stop sw is should be a paper folded with the diagnostics test and schematic. It is tucked under the pressure sw attached to the back. If not there then search "Maytag Neptune motor phase test" There is also a Service Manual FREE at Goetlieh's site.
Sep 27, 2008 | Maytag Neptune Washer
Neptune MAH3000AWW will start to fill when start is pressed, but stops seconds later
either a faulty pressure switch / pot or faulty controller - either way you will need to call someone in.
Jul 24, 2007 | Maytag Neptune Washer
Washing Machines Logo
239 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
