Euro-Pro EP91 Quad-Blade 6 Cups Food Processor
Euro-Pro EP91 Quad-Blade 6 Won't Start
posted by sandic105 on Jan 05, 2008
I purchased the food processor described above. When I got it home and plugged it in, it will not start. Any ideas?
Thanks, Sandi
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 25, 2008
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Had the same problem. There is a tab on the lid that hits the handle when you turn to the locked position causing the lid not to fully engage the safety switch. Try lifting slightly on the lid near the handle of the bowl causing the tab to pass over the handle. It should only move a little bit causing the switch to engage. I not sure if this is suppose to there or a defect.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Euro-Pro EP91 Quad-Blade 6 Won't Start:
I don't want to Accept this solution
Can you Help with these Food Processors problems?
Food Processors
Looking for instructions and Users Guide to...
Food Processors
I bought a used heavy duty foodprocessor at a thrift shop....
Food Processors
Model #6123 plastic gear that broke on back side of blade
Euro-Pro EP91 Quad-Blade 6 Cups Food...
I have lost the piece that pushes the food through the...
Will not run if not properly assembled and it is difficult...
Loading problems.
Repair Service
Find Food Processor Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
