Home and Lifestyle Software
Problem for Home and Lifestyle Software
Generic problem for all Home and Lifestyle Software
Program!!
By radthedad on Jan 05, 2008
  1. hi had a antispyware program called sunbelt counter spy i have uninstalled most of it but obviouly not all so every time i start to surf the internet it starts to try to install itself then shows me a message of error 1706 cant find files could you tell me how i could delete the remaining part of the program as unlocker wont work nor will going to the control panal many thanks for a swift reply j
Comments:
Jan 06, 2008
- adf
Best Solution
posted on Jan 24, 2008
Very Helpful)
Aimiel
Rank: Wiz
Rating: 85%, 353 votes
Here is a procedure (pasted below) which a Beta tester of CounterSpy developed having to remove and re-install various versions and running into the same problem you described. I would suggest reading through the discussion thread (CLICK HERE) before proceeding.
Hope this will FixYa!!!
____________________
Manual Uninstallation of CounterSpy 2.x
1.Open Task Manager and be sure none of these three are listed
a) SBCSSvc.exe (CP service)
b) SBCSTray.exe (tray icon)
CounterSpy.exe (CS main app)
If any are listed click "End Process"
2. Be sure the CS directory is gone. The standard location is C:\Program Files\Sunbelt Software\CounterSpy
3. Remove additional folders that may be located at these three places:
a) C:\Documents and Settings\All Users\Application\Data\Sunbelt Software
b) C:\Documents and Settings\user\Local Settings\Application Data\Sunbelt Software
c) C:\Documents and Settings\user\Application Data\Sunbelt Software
4. Run the Windows Installer Cleanup Utility. If anything is listed for Sunbelt CounterSpy, select and hit "remove".
5. Look in C:\Windows\Downloaded Installations and
C:\Program Files\Downloaded Installations
you should see one or more sub-folders with names like
{XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX} where the X's are random numbers. In each sub-folder will be an .msi file. Right click the .msi file and select properties. Look in the summary tab for indications that the .msi is an installer for Sunbelt CounterSpy. Delete the sub-folder, the one with all the numbers (do not delete the \Download directory folder)
6. Look in C:\Windows\Installer directory where you will find .msi files. Again, right-click each .msi and select properties. If any .msi files are Sunbelt CounterSpy, delete only those .msi files.
7. Look in C:\
if you have any {XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX} delete those folders.
8. Open Computer Management console utility (Control Panel-->Admin. Tools-->Computer Management) and select the Device Manager then click on View and select "Show hidden devices" . Expand the Non Plug and Play Drivers tree and scroll down until you find the SBHR device driver. Right-click on it and select uninstall.
The console will prompt you to reboot. Do so. If you don't find any SBHR device driver, there is no need to reboot.
9. You need to download a zip file at the bottom of my post. Follow the directions to be sure it is clean before you use it.
10. Check C:\Windows\System32 for the following 6 files and remove any if they are present:
a) SBAPIFS.sys
b) SBBD.exe
c) SBProt.sys
d) SBRC.dat
e) SBFC.dat
f) eSellerateEngine.dll
I also had a file SBProt.bak and asked if it was safe to remove; it was.
11. Check C:\Windows\System32\Drivers for the following three files and remove if any are present:
a) SBTEDrv.sys
b) SBHR.sys
c) SBAPIFS.sys
12. Last, if you have any Sunbelt CounterSpy desktop, tray or start menu icons remove them and reboot.
Was this helpful?
Yes
No
Popular Solutions for Home and Lifestyle Software
Questions and Unsolved Problems for Home and Lifestyle Software
Answer
I am considering to buy officesuite 2009 instead of the expensive Microsoft Office. Would this be a... (More)
Answer
DVD movie has slurred speech, a little slower playback, a bit crackly voice. playing movie off... (More)
Answer
Upon downloading Wolfenstein 2 from Steam client the Wolfenstein 2 exe seems to bring up Notepad... (More)
Answer
after loading widows update KB973688 firefox won't work. Firefox will only load once and ,once... (More)
Answer
My Sirius Studio software is stuck on ''loading please wait'' so it cannot load channels.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Home and Lifestyle Software:
Top Home and Lif... Experts
Rank: Guru Guru
Solutions: 1414
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Home and Lif... Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
