Posted on Nov 07, 2009
Pioneer vsx-305 need wiring diagram for this connection to the HTP100-SW (Subwoofer) & 5 surround sound speakers
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2912
Points
6
I have problem with connecting subwoofer to receiver.
  • yobm Apr 04, 2011
    We're having the same problem. Got a good deal on this unit at a yard sale, but realizing later it doesn't have S-Video, subwoofer input, or even an TV mode. We have it working using the DVD mode (took all damn day.....) on the TV, but seems either the center speaker works or the front ones, but not both. The rear speakers pick up some of the channels, but we can't hear what the people are saying :P Long story short, I want to hear what people are saying on all 5-6 speakers. Also same problem as scottieporie b/4, where do I hook up the subwoofer? Thanks for taking time to answer my problem.
Dan Marazzito
Level 1:
New Friend:
  • Posted on Jan 22, 2015
Dan Marazzito
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2912
Points
What cable do you need for the sub? If it's an RCA try to cut off one end of a cheap rca cable, then connect it to one of you rears.
Wire diagram pioneer http-100 sub woofer
If you wish to get some details; check the site linked here. Pull up older posts.
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
4helpful
Looking for owners manual & how to connect to the speakers (6 each) HTP 100-SW sound system. Thanks
The front speakers go into the sub in the two bottom inputs from the receiver. the two upper are outputs to the actual speakers,SOYOU RUN RUN THE FRONT SPEAKER WIRES FROM THE RECEIVER TO THE INPUT OR LOWER CLIPS ON SUB,THEN RUN WIRES FROM THE OUTPUT OR UPPER CLIPS FROM SUB TO THE FRONT SPEAKERS.
3helpful
How do I hook up speakers?
If you are referring to 5.1 surround you would have to have 5 speakers plus one powered subwoofer. The front left and right as well as your center channel to the majority of the sound reproduction with the rear channel being there for intricate sounds and background noise. The subwoofer will be a preamp output from your receiver. That signal will then get amplified by your subwoofers power amp. Generally subwoofers are tucked away in a corner while the other 5 speakers form a box around your viewing area.
Problem for Pioneer VSX-818V-K 5.1 Channels Receiver Surround sound doesn't work, display reads 2CH IN,surround speakers are enabled,automatic test will find surrand speakers
Test with an surround sound media ie. Blu-ray or DVD)_. Disconnect the front and all other speakers that are working to see if sound from the missing speakers are heard. If this doesn't work then start by tracing and checking all the wires from the receiver to the speakers for bad/shorted/open connections.
PLEASE VOTE IF THIS WAS HELPFUL. THANKS & GOOD LUCK.
2helpful
Pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
No Sound from Subwoofer
The original Pioneer subwoofer has its own amplifier built in to the speaker, so the only cable required on the original speaker is a single RCA cable. To connect a different brand subwoofer to the Pioneer you will have to make sure that you have a subwoofer with the same specs. It will need its own built in amp to work, as you can only connect it with one RCA
Pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
Amatuer needs sub-woofer advice for Pioneer VSX-454...
Based upon your description, the subwoofer is just a speaker and is taken from the normal speaker outputs. Run your A channel to the sub and then from the sub to the left and right front speakers. That should do it.
Dan
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
