Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
Propane heater I have a wall mounted vent free propane heater. It will light and fire but once running it will only run about two mons. There is no odor. I did vaccume it. I has sat all summer with pilot off. I thought cleaning was the issue but it still does not continue to run. Any help would be appreciated. Thanks, Kathleen
I recently had a similar problem with my DESA wall-mounted vent-free natural gas heater. We had it repaired but the problem recurred annually until it wouldn't stay on, even on low. There is a part known as an oxygen depletion sensor (sometimes called a flame sensor) that is part of the pilot assembly. When it is working properly, it sends a very tiny current that lets the heater know to keep feeding gas. After a few years the sensor can get rusty, which interferes with its electrical job, causing it to tell the heater to shut off so it doesn't kill you. A temporary repair can be effected by removing the part and cleaning it with sandpaper or emery paper. I suppose compressed air might work too but probably not for long if it is impeded by rust and not just dust. I found all this out from the repairman who thought he had it fixed and then it went out as he was leaving. He couldn't find the part but I found it online at a DESA-authorized distributor and it was about $40. He installed it in about 10 minutes and it has now worked like new (it's at least 15 years old) for over a month.
Posted on Feb 24, 2009
I use canned air and it solves the problem for a while. Shut it off and then spray that where the pilot light is. Wait a little while and turn it back on. Every once in a while you have to clean it out too. I use the canned air at least once every two weeks or mine does what you describe.
Posted on Feb 09, 2008
    Problem Solver:
  • 7 Answers
Make sure that the pilot assy is clean... really clean and rust free. A small wire brush and a toothbrush are two really great tools to use to get that baby clean. If that doesn't do the trick, something else must be wrong and will need to go to the pro's for repair.
Posted on Jan 05, 2008
1st panel on Vanguard 22,000 btu ventless propane wall unit has overshooting flame causing strong exhaust-like odor in house. Has black residue coming out of top vents. No fan on this unit.Help!
good thing that you turned it off as it is now not operating as designed and that makes gas dangerous
call an accredited gas fitter to properly diagnosed the problem and repair/ replace it
Jan 01, 2017 | Vanguard Heating & Cooling
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Problem is with my Rinnai propane gas heater in my LIVING ROOM, not car. Please see previous question. Thanks.
Turn it off. Check connections and hoses with very soapy water for leaks (it will bubble)
If you can't find it... I would either return it if possible... or go take it to a propane professional for testing.
Dec 20, 2012 | Rinnai Energy Saver Direct Vent Wall...
I have a Kozyworld wall mounted ventless propane heater. Whenever it automatically turns ON or OFF you get a strong odor of propane. While it is ON you don't smell propane. What is wrong with it. I...
You need to clean it out. Take the wall heater down and use a air compressor to clean out the gas system. Also clean the orifice out. Make sure that the chamber is clean and clear of spider webs and dust.
Jan 26, 2011 | The Companion Group Kozy World Portable...
I have a vanguard wall mount unit,natural gas model # vn25501tb serial #7709362,i smell a terrible smell when its burning every once in awhile,sort of like when a kerosene heater runs out of fuel,is there...
PLEASE CHECK THE OUT SIDE VENT AND MAKE SURE THERE IS NO SOOT BUILD UP. IF SO TURN OFF AND HAVE CLEANED. DID YOU JUST PAINT WITH AN OIL BASE PAINT? THIS WILL CAUSE AN " KEROSENE" TYPE ODOR WHEN FLANE IS ON.
Jan 05, 2011 | Vanguard Heating & Cooling
Glo Warm Self Venting Heater Model FB3B Emits strong odor
The propane may have a higher sulfur content; however, the odor may go away soon. It is probably caused by the dust and oxidation (micro-rust) that attached itself to every part of the heater while in storage, even though it was "sealed".
Sep 29, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Shuts off when switched to low and smells when running.
clean the burner and the orifice you can use a air line or blow off a vacum cleaner
Nov 20, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Empire Wall Heater(propane) won't stay lit
You have a crack in your heat exchanger and it is sucking in products of combustion. Replace the heater. OR there is a blockage in the intake or exhaust vent. GET IT FIXED OR REPLACED!
Dec 05, 2006 | Empire GWT-25 Wall Mounted Panel Heater
Heating & Cooling Logo
192 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
