The Palazzo is programmed to descale the boilers on its own, when set in the correct mode. You program the machine to descale it’s self, do the following. With the machine turned on, push and hold the left 2 buttons (clean and pre-ground). This should light the top right red indicator light. Mix your descaling crystals in 32 to 48 oz in your water tank. Stir until they are completely dissolved in the water. Next, have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz’s. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the bottom will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, and then close, and then open the steam knob again and let the water just flow through the boilers until it is emptied by the machine. Don’t turn off anything until the machine stops on its own. This will clear the descale light. You will have a steady red light and the green light will be blinking. Refill the water tank again with fresh water, close then open the steam knob, this will clear the red light and your ready to go.
Was this helpful?
Yes
No
Popular Solutions for Solis Palazzo Espresso Machine
I am trying to find the interior pump stem and glass dome for the lid of a Royal Hallmark #5835 35...
(More)
I am trying to find the interior pump stem and glass dome for the lid of a Royal Hallmark #5835 35 cup coffee urn. jacquevfa@bellsouth.net
I went to use my coffee machine & I noticed that it had no power nothing.I tried to turn it off...
(More)
I went to use my coffee machine & I noticed that it had no power nothing.I tried to turn it off & but nothing.Tried another plug still nothing. Can anyone help me with what the problem might be or where can I take it for repair in the Montreal area. Thank you.
My Thermometer light is on. It does not make coffee and water coming out of frothing tube is cold. I...
(More)
My Thermometer light is on. It does not make coffee and water coming out of frothing tube is cold. I do not think the element is working.
The black plastic L shaped, water tank to silicone tube, connector is cracked and leaking. How can I...
(More)
The black plastic L shaped, water tank to silicone tube, connector is cracked and leaking. How can I get a new part?
