Question about Hotpoint HSS25GFP Side by Side Refrigerator
No water on door dispencer
I have hss22ifme and i cant get no water on the dooe and i cant get the auger to turn for ice
  • 90 Answers
If you cant get dispenser to work at all it could be a switch problem in disp. Are the lights on at the disp. if not could be power problem
Posted on Jan 05, 2008
Side by side ice maker won't stop letting ice out of dispencer unles you open freezer door
It sounds like a sticking actuator switch. the door light switch shuts off the auger motor when you open the door.
Aug 15, 2014 | Refrigerators
Whirlpool ed5gvexvdoo side by side When using the ice dispenser (cubed or crushed) it will not dispense. I have pulled the ice tray and the motor for running the dispenser arm runs. I have emptied the tray...
this maybe a problem with you auger motor may be stripped.open the door remove the ice bin.then hold the metal u shape auger arm and try to turn it by hand or have some one try to dispence ice if the u shape braket turn easy ny hand or if it stops turning when being held replace the auger motor.i hope this is some help,good luck you may also have to replaced the ice bin.
Jan 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Broken ice dispenser
try and remove the ice bin.the watch the auger motor while the door is open and the switch help close while some one is tryind to dispence ice.if the auger turns the check and see if the u shaped braket is stripped you can tell this by grabbing it and turning back and forth it should only move one way.if it does not turn then the auger motor does need to be replace.make sure to check the wiring as well.if the motor turn check th is bin and make sure there is no ice jammed in the teeth of the auger this wolud stopp it from turning.i hope this was some help to you good luck. would like to here how things go for you.
Jan 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My ice maker makes plenty of ice, no problem with the water either. My problem is that the auger will not turn to dispense the ice out of the bin. The motor kicks on when you push in the buttom, however it...
Pull the ice bucket out, then hold in on the door light switches and while you push a glass into the button for ice (may require two people). Ice dispenser and auger will only work, when you push for ice, when the freezer door is closed, so by holding the light switch(s) in the off position with door open you can simulate door being closed. If you can push the button and see the auger drive turn (with ice bucket out) then check to see if you have some ice stuck between the blades on the bucket, if the auger motor doesn't turn, it may be "ice frozen". Common problem. Remove motor, let sit on counter for about three hours and then reinstall, if it then works then check for water dripping from the fill tube, where the water comes into freezer for the ice maker, and see if it is dripping onto auger motor.
If you put auger motor back in and it still won't turn then more and likely you need an auger motor.
Let me know.
Oct 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice dispencer not dispensing ice
Ouch, if your auger won't turn, pull out the ice tray unit. At the back you will see the gear for the auger unit. Try and move it, both clockwise and counterclockwise. If it won't turn - you have a motor problem and needs replacement. If it turns too freely, then you have a weak motor and it will not push the ice.
Aug 21, 2009 | Frigidaire FRS26R4A Side by Side...
The icemaker makes ice, but it won't dispense.
rmielsen and PhyllisForbe,  Your refrigerator has an auger motor that causes the ice to be dispensed when you press the ice selector on the front of the refrigerator.  You could have several possible problems that will gives you the same result.  The auger motor could be at fault. The ICE selector part of the  control panel of the front of the refrig could be at fault.  To isolate to auger or control... do the following.  Remove the ice bucket or auger assembly from the freezer. Reach into the freezer compartment where the auger assembly normally would be.  You should be able to see a "horse shoe shaped metal drive assembly" that would mesh with the auger assembly (ice bucket) to turn the cork screw shaped auger. Try and turn the auger drive assembly in rear of freezer to determine if motor armature is free.  The is somewhat difficult to do because the auger motor is high torque, slow rpm motor, but it should turn if it is good. Sometimes the auger motor will become stuck due to a water leak, inactivity, high humidity during a defrost cycle, etc.  The more possible suspect is the ICE selector assembly on the front of the refrigerator.  If any function on the refrig fountain dispenser control panel goes bad...then the ice/water control assembly will need to be replaced.  Hopes this helps you!  HandyHenry
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Jan 30, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side
Hi, it sounds like you have a bad auger motor on your dispencer. If the button works for water, usually it will work for ice. It is also possible that you have a bad dispencer control board. If you would provide me your model # I could assist you further.
Dec 02, 2008 | Refrigerators
Why doesn't my ice maker work?
You do not list model number, so this will be very generic. If you have cubes in the ice bin, and when you try to dispense them the duct door opens and the auger motor runs, check the auger in the ice bin itself. Check where the spiral auger meets the plastic part on front of the auger. Drive part likely seperated.
Nov 21, 2008 | Refrigerators
Ice will not dispense GE model GSL25IFRF BS
well if you trouble shoot the board at the back to see if you are getting voltage if you are then use a jumper on that conenctor and see if the auger motor runs or remove auger motor and check voltage there while pressing the lever for ice usually 100% of the time that board controls everyhting water and ice
Nov 17, 2008 | Refrigerators
GE 23.5 CU FT side by side w/ice maker and water in the door.
replace the dispenser control under the front panel on the freezer door if need detaild instuction after receiving parts reply to me
Jan 15, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
56 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
