Home | Toshiba | 55H70 55 in. Rear Projection Television | Looks like 3D - the red...
Toshiba 55H70 55 in. Rear Projection Television
Problem for Toshiba 55H70 55 in. Rear Projection Television
Looks like 3D - the red won't converge and is distorted
By lesherj on Nov 07, 2009
Blue color fine, but red is distorted and can't make it converge. Is the tube damaged beyond repair? It looks like 3D without the glasses
Comments:
Nov 07, 2009
- Any guidance on how to get at, identify, remove and replace the chips would be helpful. I do have a solder but I've never unsoldered anything. Nor have I worked with chips before.
Best Solution
posted on Nov 07, 2009
Very Helpful)
SD Tech
Rank: Guru  Toshiba Televisions & Videos  Expert
Rating: 97%, 856 votes
55H70 model uses two of the STK-392-110 CONVERGENCE IC CHIPS.
If red is skewed and will not adjust you need to replace both chips and any of the protect resistors around them that are gone---Most of the time just the two chips need to be replaced.
You can buy a pair of the chips on Ebay for less than 12 dollars plus shipping----
The chips are black in color--2 1/2 wide X 1 1/2 tall with 18 pins each and are mounted on large metal heat sinks side by side----THEY WILL HAVE THE STK-392-110 PRINTED ON THE FRONT OF THEM IN WHITE.
The question is are you able to do this yourself? If you can you can save the set and a lot of money--most shops are going to charge 300 or more for this kind of repair---IT SHOULD BE FIXABLE IN YOUR HOME.
I HAVE repaired hundreds of these sets--just got back home from doing a Panasonic that uses the exact same parts your set uses.
The chips fail because a white grease to quickly transfer heat from them to the heat sinks dries out after time and one of the chips goes.
Let me know if you need more directions--the hard part of this repair is getting at the chips and the ability to unsolder and replace them.
TOTAL PARTS COST SHOULD BE UNDER 25 DOLLARS.
If this information has helped you, rate this solution as I do this here for free.
SD TECH
Comments:
Nov 07, 2009
- THEY ARE GOING TO BE LOCATED EITHER ON THE BOARD (AS YOU LOOK FROM THE BACK) ON THE FAR LEFT FACING FORWARD or THE NASTY VERSION HAS THEM ALMOST DEAD CENTER IN THE SET ON TWO LARGE HEAT SINKS,,,
IF YOU HAVE NEVER SOLDERED I AM NOT SURE THIS IS A JOB FOR YOU---IF THEY ARE IN THE MIDDLE OF THE BOARDS---CABLES HAVE TO BE UNPLUGGED TO GET THE ENTIRE CHASSIS FREE AND UP SO THE BOTTOM OF THE BOARDS FACE THE BACK OF THE SET!
UNLESS IT IS THE VERSION WITH THEM ON THE FAR LEFT BOARD---THE HARD PART WILL BE GETTING AT THEM.
What you need:
TWO STK-392-110 CHIPS (I CAN TELL YOU BEST PLACE TO BUY THEM)
A good soldering Iron.
Solder (RADIO SHACK ETC)
Liquid solder flux (RADIO SHACK?)
A desoldering braid or wick (RADIO SHACK?)
Some acetone or denatured alcohol to clean the board after they are removed.
HEAT SINK COMPOUND---a white grease to apply to the back of each chip before you install it.
If you cannot do it see if any of your friends can or know someone who can.
I don't have your email but if I did and you sent me a few photos of the inside I could tell you how hard a job you have----RULES HERE DO NOT ALLOW ME TO POST MY EMAIL ADDRESS..............................
SD TECH
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Very detailed and informative. I can't believe someone with so much knowledge would be so giving with his/her time " - lesherj
Solution #2
Not Helpful)
azbudgettv
Rank: Master  Televisions & Videos  Expert
Rating: 82%, 10 votes
What you have is a convergence issue, not a damaged tube. It can be easliy and inexpensively repaired.
Was this helpful?
Yes
No
Popular Solutions for Toshiba 55H70 55 in. Rear
Questions and Unsolved Problems for Toshiba 55H70 55 in. Rear
Do you recommend Toshiba 55H70 55 in. Rear Projection Television?
Answer
Answer
the color on peoples faces is pink. It seems as though the green tint is gone
Answer
the color tint is like pink on peop[les faces and it used to go to the correct color after it was on... (More)
Answer
How do you remove the front panel of our 55" Toshiba for cleaning
Answer
My tv is a Toshiba 55H71 but this is the closest number i found to it. We are having problems with... (More)
Answer
TV was flooded. Already cleaned and ready for re-assembly. We need a circuit diagram to check... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba 55H70 55 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
