Washing Machines
Problem for GE Washing Machines
Generic problem for all GE Washing Machines
Washer not draining
By thymon652 on Nov 07, 2009
washer not draining
Solution #1
posted on Nov 14, 2009
Not Rated)
ginko
Rank: Guru  Washers & Dryers  Expert
Rating: 89%, 5064 votes
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water. The pump is located behind a panel at the front lower side of the machine.
Keep a container ready to collect water when you undo pump hose.
If all the rest is OK, test and eventually replace timer board. Problemwith water pump are far more commonly causing this problems thenfaulty timer board.
Parts and diagrams available here.
Was this helpful?
Yes
No
Solution #2
posted on Nov 07, 2009
Not Rated)
orlandoman20
Rank: Master  Washers & Dryers  Expert
Rating: 100%, 6 votes
a lot of GE washers use a separate motor/pump assembly that is supposted to drain the tank before it spins. That motor is not very strong and can stall if it gets a little clogged with hair or lint or cloth threads. My dad's did that from tassels from a bed spread that fell off in the wash. You can take the front cover off with a knife blade to push the lock clips in so the cover pulls off.
when you do that you can remove the hoses to the pump and pull the clogged material out.
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
elite oasis is that a quaitly machine
Answer
What is the most reliable top loader washer to buy?
Answer
my washer is stuck in spin cycle every time i turn it on it goes right back to spin cycle only no... (More)
Answer
My GE WSM 2420 top load stacked washer (specifically, the drum tub support) broke (the washer tub is... (More)
Answer
HE2 plus shuts down with F-20 error code about 9 minutes into every cycle. We have had the pressure... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Washing Machines:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14870
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
