Mitsubishi WD-57734 57 in. HDTV Television
Problem for Mitsubishi WD-57734 57 in. HDTV Television
No sound great picture
By tatelman on Nov 07, 2009
I have a two year old Mitsubishi WD-57734 tv that suddenly has no sound, but the picture is fine.
Solution #1
posted on Nov 07, 2009
Not Rated)
sabreusa
Rank: Guru
Rating: 89%, 15 votes
Are you connected to a Cable box? then make sure cable box is not on MUTE and audio cables are attached.
From MENU check to see that speakers are not disabled on your TV.
Good Luck
N Sabre
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WD-57734 57 in.
Questions and Unsolved Problems for Mitsubishi WD-57734 57 in.
Do you recommend Mitsubishi WD-57734 57 in. HDTV Television?
Answer
Answer
I heard a pop in my televison and now I have no pictiure or sound but the power is still on Can it... (More)
Answer
when i turn on the air condition the engine doesnt accelerate but instead it cuts off. my mechanic... (More)
Answer
when the tv is turned on a message at the bottom says the tv will turn off in a few seconds and to... (More)
Answer
tv will turn on, but in 2 seconds it turns off. unable to get tv to play at all!
Answer
It keeps on cracking and poping as long as have it on.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WD-57734 57 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
