Question about Canon PIXMA MP530 All-In-One InkJet Printer
Check Ink U130 5BK
Hello, and happy new year !
I have a problem, i fill a new cartridge and after i print more pages, the error apears: Check Ink U130 5BK.
I try to press any buton, ok button, but nothing happens. Seems that is locked.
Pls help me.
  • 1 more comment
  • bebef Jan 08, 2008
    Press and hold the stop/reset button for at least 5 seconds
  • harold227 Aug 12, 2008
    needed to press and hold down reset button two times and then this did work. I regurlarly refll canon cartridges on this model and this will always solve problem. very helpful.
  • Indyb May 11, 2010
    Could
    the plotter Canon IPF 8000s work with ink direct feeding ?
Hold down the Stop/Reset button for 5 seconds or so - should start working now - although this stops the low ink warnings from then on
Posted on Jan 21, 2008
    President:
  • 4,402 Answers
Replace with a original cannon new cartridge and try again
Posted on Jan 09, 2008
Hp officejet j4580 flashing "incompatible
hello
you must purchase original ink cartridges -- not all compatible cartridges are built the same..
i would suggest buying authentica , from HP dealer or reseller
go to www.compluscominc.com, they will help you for sure and let you kno what to buy and how much
CC653AN icon_x.gif Contact Reseller
HP 901 Black Officejet Ink Cartridge - Prints approximately 200 pages (North America)
RoHS: Modified
CC654AN icon_x.gif Contact Reseller
HP 901XL Black Officejet Ink Cartridge - Prints approximately 700 pages (North America)
RoHS: Modified
CC656-30001 icon_x.gif Contact Reseller
HP 901 Tri-Color Officejet Ink Cartridge - Prints approximately 360 pages
RoHS: Modified
please send me 4 thumbs up
Aug 12, 2011 | Office Equipment & Supplies
Printer is not printing
hello...........
It seems this is a problem of ink.....
Try to get a new cartrage................
If that is ok then check the driver whether it is install or not.............
If that dont work let me know ill give you detailed instruction .........
happy computing
Jun 21, 2010 | HP LaserJet 1020 Printer
Printer is hardly used. Has been stored in a dry celler for 3 years. now I want to use it and can command to print pages which it does but prints blank pages. The ink cartridges are surely dried out;...
Had a good read of the manual, which can be found on this site and I think you must fill the cartridges with ink, otherwise you could cause damage to the printer if you continue running it empty. The instructions for filling them manual can be found on my tip on filling PG40, CL41. You should also try standing them first in a saucer of ink cleaning fluid which you get with refill kits. This might clean the nozzles. However I would run the expense of buying new ones first, shop around on the net, they are coming down in price!
Jan 05, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Cartridge error:remove cartridge and reinsert cartridge on left, already cleaned, still happening, when put in new black ink, printed the alignment page out and then error showed, cannot print, fax, etc,...
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Dec 12, 2009 | HP Officejet J5780 All-In-One InkJet...
Printing blank pages
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 09, 2009 | Brother MFC 420CN All-In-One InkJet...
I filled my cartilages but they printer says they are empty
If you refilled the cartridges with a refilling kit then this error will continue. You see, cartridges have a chip installed on them and it is programed to calculate approximate ink remaining after a certain number of pages are printed.
For eg, a chip on a new cartridge is programed that a full page takes say .5 ml, then if you print 1 full page or two half pages, it will deduct .5ml from the ink volume. When it reaches zero, it does not know how much ink is in there; it never knew in the first place. Now if you refill it up, the chip just thinks that all the pages have been printed so the cartridge must be zero.
In short, this error will stay, if you are able to print ignore the warning and continue to print until the print quality degrades. If you are unable to print you might have to install a new cartridge. OR if you're luck, you may find a chip reseter on the internet or from the refill service.
Dec 07, 2009 | HP Photosmart C5280 InkJet Printer
Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
May 27, 2009 | HP Business InkJet 2800 Printer
Check print cartridge error
Try pushing it gently using some pressure. I had the same problem and it got solved using a little push.
Aug 27, 2008 | HP PSC 1210 All-In-One InkJet Printer
New black print cartridge is getting a "low ink" error message
too generic and too lack of info to help precisely but try reinstalling the drivers, FIRST uninstall all HP stuff completely and reboot your system. After reinstalling take both cartridges out, buy a bottle or spray of isopropilic alcohol and clean the cartridges contacts carefully. If cartridges are new and genuine there is no need to do that of course.
Mar 15, 2008 | HP Photosmart C4180 All-In-One InkJet...
Printer "prints" but when it's done, no ink shows on the page.
When you filled your cartridges were they empty? If so there is a good possibility that the nozzles are gummed and dried up. If you are going to fill them yourself watch the indicator that comes up on the screen it will tell you when you are getting low. If you get a low indication fill it asap. This will keep your nozzles wet and free flowing. Waiting until its empty can cause them to gum up and altimately dry out. My solution is to go to the store buy brand new cartridges. Go through the the full set up that your manufacture recomends. This means using the install new ink cartridge utility that came with your printer. Print a test page and print a nozzle aligment page. Just remember never let your ink completely run out before filling. If you follow this you will never run into this problem again.
Sep 21, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
1,039 people viewed this question
old marine
old marine
