Question about Lexmark X75 All-In-One InkJet Printer
Lexmark X75 Power cord and cable are all hooked up and plugged in but the printer won't turn on. There is a buzzing sound from the box that goes into the printer from the power cable
  • 4 more comments
  • RickwNJ Jan 12, 2008
    I have lost my install CDs anyone have a copy they can share?
  • witchypink Mar 02, 2008
    i am having the same problem with my lexmark x75 printer. it will not turn on and there is a weird buzzing sound coming from the box that plugs into the printer from the power cord. how can it be fixed? do i need to get a new power cord?
  • PegasusC Mar 12, 2008
    I have the same problem. That box is the power supply & it needs to be replaced. Good luck finding the part. I called 877-577-2787 & they claim the power supply is part #21D0625 & the power cord is #11B5626 but when I pull these part numbers up on their website (parts.lexmark.com), I don't see the X75 listed.
  • Anonymous Mar 15, 2008
    I am having the same problem. There is a buzzing sound that comes from the adapter, but the printer will not turn on. Since it seems impossible to find a new one, is the printer garbage now?
  • bestbestgirl Sep 09, 2008
    I've purchased a new power cord and the printer came on for a minuter and shut back down
  • Anonymous Dec 22, 2008
    X75 will not switch on-have tested the power supply and that is ok, though delivering 40 volts when not under load.
    Problem Solver:
  • 35 Answers
To RickwNJ,
The lexmark web site has the drivers, but not for Vista, iirc.
Best wishes
Posted on Jan 15, 2008
Power to switch, will not come on, is there a reset button?
Try to unplug the power adapter from the printer. Disconnect the power cord from the power outlet in the wall.
Wait at least 10 seconds before you re-plug the power cord into the power outlet (bypass any power strips or surge devices). Re-plug the power adapter into the printer. If printer won't automatically power on, press the power button. If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Jun 27, 2011 | Lexmark X75 All-In-One InkJet Printer
Just bought the RCA1023 and i have a buzzing sound trying to fix it i have it hooked to my tv through the HDMI cable i also have the audio cords (red and white) hooked up and i am still getting a very...
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
Try rotating the power cord in the wall outlet.
If it still does it with no cables or anything external attached it
Apr 01, 2011 | RCA Audio Players & Recorders
Am look for printer cord for an lexmark x75
I had that same Problem. I need the Power Cord, and Power Supply, that came with it. I called Lexmark, told them what I needed, and I receivec it, within two days.
I also needed the USB Cable, that connects to the computer. I found that at "Amazon.com." very cheap.
Oct 05, 2010 | Lexmark X75 All-In-One InkJet Printer
Have lost my power cords for the x75 and need to know what I need/
Just contact Lexmark technical support to request for the power cord for your Lexmark X75. When calling support, you will be asked for your printer model and the serial number. Thanks.
Aug 26, 2010 | Lexmark X75 All-In-One InkJet Printer
I need a power supply cord for lexmark x75
Hello. Lexmark can better assist you with your request for the power supply cord for your Lexmark X75. You can contact them at 1-800-LEXMARK (1-800-539-6275).
Apr 07, 2010 | Lexmark X75 All-In-One InkJet Printer
Lexmark x75 all in one. Started with communications device error. could not print. went through troubleshooting-still wouldn't print. started printing randomly(not initiated by me). Couldn't clear print...
Hi. That's quite a problem you have there. Have your attention first on the power supply. It does get hot but it's unusual if it gets very hot. Take out the power supply (the black box behind the printer where the power cord is attached). Check the power specifications. Most of the Lexmark power supply has input ranging from 120-240 Volts and an output of 30 Volts. Make sure you're plugging it in the right voltage range. Check if you're using power surge protectors or power strip, disconnect it and plug directly into a properly grounded wall outlet. Power surge protectors can also draw power away from the printer. When everything's well, try printing again. Hope this helps.
Mar 18, 2010 | Lexmark X75 All-In-One InkJet Printer
Lexmark x75 printer/scanner
This printer/scanner, hooks up to the computer via USB. The USB cable goes into the back of the printer on the right hand side (opposite side from the power supply). The status blinking could indicate either; 1. No paper 2. No or very little, ink.
May 25, 2008 | Lexmark X75 MF All-In-One InkJet Printer
Printer cord
Jimmy, The Usb cable is universal. You can get one at any electronics store.
Feb 20, 2008 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75 All-In-One InkJet Printer Logo
61 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
