Question about Cameras
Canon I have a choice, buy a 5D with a 24-105 lens or a 30D with two quality lens.  What do you recommend and if the 30D what two lens would you recommend?
    Problem Solver:
  • 24 Answers
It really depends on what kind of photography you want to do.
I own both of those bodies, and the 5D is great for landscapes, portraits, and other artsy stuff.
However, the 3 frames per second doesnt compare to the 5FPS of the 30D, so if you're shooting sports, the 5D will do better.
Also, 5D is better for wide angle shots.
If you do decide on the 30D, again, lens choice really depends on what kind of shooting you plan on doing.
Posted on Jan 08, 2008
The DSLR Camera Canon 5D mark 3 is better option for the wedding photography?
I think it is due to the extensive choice of quality lenses.
Nov 21, 2017 | Canon Cameras
How to mount 67mm thread lens to t4i body only canon
One side of the reverse adapter has a 67mm thread, the other side has a lens mount. Mount it to the camera body as if it were a lens. Bear in mind that it's intended to screw onto the front of a lens and then mounted onto a camera to put the lens onto the camera in a "backward" position.
Dec 16, 2012 | Fotodiox 67mm Filter Thread Macro Reverse...
I have error code #99 on a canon eos 30d
Error 99 is Canon's default for several "connection" problems most common are dirty contacts between the lens and camera body. Another is the contacts in the battery compartment both the camera and the battery contacts should be cleaned.
The camera might not be able to read the memory card, download the pictures to your computer and format the memory card don't delete them format the card this function is found in the set up menu.
Formatting is one of the most important functions to keep the camera and memory card communicating AND is the most neglected function. Always format a new memory card and always format a memory card after downloading pictures to a computer. Format a memory card if it's been in another camera.
Cleaning the lens and body contacts can be done fairly easily with a clean pencil eraser, don't use a puffer on the body as you will blow dirt into the camera. With the lens removed hold the camera as much as possible with the lens opening pointed down and gently polish the gold contacts. Do the same with the lens contacts make sure both areas are clean and re install the lens to the body.
Possibly the most important "fix" is to update your camera's firmware. Go to Canon's web site (it can be a bit intimidating at first) and search through until you find the firmware updates for your camera. Download this generally they want you to download to a memory card then place the card into the camera and upload the new firmware updates.
The Canon 30D (in my opinion) is one of the best no frills, greatest working DSLR cameras Canon produced. Not saying the model's beyond are not it's just the 30D isn't loaded down with video functions. Great all around working camera, sorry my rant for the day.
Cheers have fun with your Canon 30D
Apr 09, 2011 | Canon EOS 30D Digital Camera with 18-55mm...
Will this Lens fit the Canon DSLR 1000D
Yes, it will fit Canon 1000D.
But I'll recommend you to try lens in a shop before buying - picture quality can be low.
Jun 24, 2010 | Rokinon 6502600 mm f816 for Canon
Try and fit Canon EFS Lens to EOS 5D Body
As far as I know, you should use L series Lens to fit Full Frame Canon Camera (5D & 1D).
That would be no adapter, but please correct me if I'm wrong.
Jan 13, 2010 | Canon EOS-5D Digital Camera
How to add EX 580 flash external
You need the wireless adapter for this, you cannot do this with the camera.
Oct 19, 2009 | Canon EOS 5D Mark II Digital Camera
Error 99 canon 30d slr camera
err 99 is moisture or dew inside the camera.
May 11, 2009 | Canon EOS 30D Digital Camera with 18-55...
Hi all, I wonder if you can supply some advice regarding a Sigma17-35mm lens I purchased earlier in the year. Basically if I use the automatic or 'P' setting on my Canon EOS 30D camera the image is over...
Try your EOS in AV (aprature value) mode. You should be able to adjust your aperature value in 1/3 or 1/2 steps dependind how you have your Custom Functions set in your camera's menu. Possibly the lens you purchased is for an EOS 35mm. If you use a 35mm lens on your eos there are some calculations you must use. When using a 35mm lens on the EOS 20D, 30D, 40D and 50D bodies, you must first calculate your focal leingth by 1.6 times. With this, your exposure changes as well.
The only EOS Digital SLR bodies that use a 35mm x 24mm CMOS sensor are the 1D and 5D. My wife uses a Tamron 18-200mm f3.5-5.6 lens on her 20D and loves it.
If this makes no difference, you may have a defective lens.
Nov 29, 2008 | Sigma Cameras
Cameras Logo
125 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
