Sanyo DP42746 42 in. Plasma Television
Problem for Sanyo DP42746 42 in. Plasma Television
I have a Zenith Flat Screen TV. After the TV is on
By terrilcg on Nov 07, 2009
I have a Zenith Flat Screen TV. After the TV is on for a short period of time the picture shows major fuzzies......pixels. How do I fix this?
Solution #1
posted on Nov 07, 2009
Not Rated)
mikeoldfield
Rank: Guru  Televisions & Videos  Expert
Rating: 97%, 23 votes
To isolate the problem...you will need to replace the power board and see if it keeps on happening and then replace the Y-sustain board and see if it keeps happening.
It could be either of those; it could sure be other things too, but those two are the primary candidates.
Note: I do not have experience with your particular model; someone more specialized or who had come accross it before may know upfront which of the two is the more likely candidate.
If I were to take a pick I'd choose the Y-sustain first.
Unfortunately I don't think there's an easy and elegant way to determine which is it; you either have to know from experience or you just try and see.
Hope this helps. If it does, please rate it or comment - I need your feedback!
Was this helpful?
Yes
No
Popular Solutions for Sanyo DP42746 42 in. Plasma
Questions and Unsolved Problems for Sanyo DP42746 42 in. Plasma
Do you recommend Sanyo DP42746 42 in. Plasma Television?
Answer
Answer
sanyo 52 inch plasma hd the tv has started consistently blinking when you turn it on.
Answer
I have a 46" sanyo plasma and the screen will go have black shadows pop on and off on half the... (More)
Answer
Tv has no video or audio. Led error system blinks 12 times, d12v. Can you find the part number for... (More)
Answer
i have no pic or sound on my sanyo dp42746 i was watching it and pic went out i still had sound... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sanyo DP42746 42 in. Plasma...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
