FixYa.com
Tags:
Panasonic Panafax UF-890 Plain Paper Laser Fax
Panafax uf-890
posted by g8037242 on Jan 05, 2008
do not receive incoming faxes
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 06, 2008
Helpful (85)
jaylex
Rank:Guru Guru
Rating: 85%, 302 votes
The likely hood is that someone has turned off auto answer check the manual how to change this the other option if it always did auto automatically then turn the machine off at the wall socket and then turn back on this will boot back how it was. (try this first) If it doesn't work then check that the auto answer is switched on.
If none of the above work then it will be the modem that is not picking up the line and will need to be replaced.
Hope the first solution helps you
Thanks J
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Fax Machines problems?
Fax Machines
canon starwriter jet 4000
hi can you help me please my... Answer This...
Fax Machines
How do you get big
How do you get big huge... Answer This...
Fax Machines
"Line in use"...
"Line in use"... Answer This...
Fax Machines
how can I replace the
how can I replace the fuser on... Answer This...
Fax Machines
i have Brother FAX-827S has
i have Brother FAX-827S has... Answer This...
Repair Service
Find Fax Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
