I suspect your fuel lines have failed, pretty common since use of ethanol in fuels. The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. It does show components and part numbers. Find it here: Poulan.com http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html The dash number of your serial number is the type.
Typical fuel system: Fuel Line Replacement by SmallEng.com http://www.youtube.com/watch?v=JrXpU70Hmi0
The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. HTH Lou Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Poulan Wild Thing 2375 18" Gas
I have a Speare & Jackson petrol chain saw purchased from argos. The chain oil feed...
(More)
I have a Speare & Jackson petrol chain saw purchased from argos. The chain oil feed mechanism has stopped working. Is there a workshop manual available so I can attempt a repair?
I have the same problem as gaffierok except it's a drive sprocket for an electric mastercraft...
(More)
I have the same problem as gaffierok except it's a drive sprocket for an electric mastercraft chainsaw MC 3000 from Canadian Tire (54-5713-6)
