LG LRTBC1825T Top Freezer Refrigerator
Problem for LG LRTBC1825T Top Freezer Refrigerator
Not cooling ,compressor not working
By civic20002ca on Nov 07, 2009
not cooling ,compressor not working
Best Solution
posted on Nov 07, 2009
Very Helpful)
shastalaker7
Rank: Guru
Rating: 90%, 128 votes
Hi, the compressor may not be working for several reasons. If you are not mechanically inclined, it will be hard to walk you through to much, but, we will try!! When you're unit is plugged in and you turn the thermostat down, is the little fan at the back on? This is the condenser fan motor. If its on and running, that's great. If not, then this can cause the head pressure to rise and cause the compressor to shut off on overload.This type of compressor does not have an internal overload but a snap switch relay wired through the common wire which opens if it senses to much heat. If this occurs, it will trip and stop compressor. After it cools down, it will reset and start again.Make sure the back of the coil is free from lint build up.Feel the compressor to see the temp of it,don't burn yourself. If you feel you want to check it more, you can unplug it and pull the cover to view the terminals to see if maybe one has burned off due to being loose. This you can repair.I would recommend calling out a service tech as we have all of the tools required to check these things.I would plug it in, turn down the temp and feel the compressor in about 15min to see if it is hot. If so, I am sure it will need replaced. Depending on the age, you may consider getting a new one after getting a estimate.I would have to be on site to properly diagnose this.If that fan isn't running, replace it, that's your problem. Good Luck,Sincerely,
Shastalaker7
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
mycho
Rank: Wiz
Rating: 85%, 82 votes
Good day.
Have you tried to check if there is electrical supply from your outlet? if there is, check with the check the electrical cable, to the overload protector, up t the thermostat.
Chris
Was this helpful?
Yes
No
Popular Solutions for LG LRTBC1825T Top Freezer
Questions and Unsolved Problems for LG LRTBC1825T Top Freezer
Do you recommend LG LRTBC1825T Top Freezer Refrigerator?
Answer
Answer
LG model LRTB2023W (top freezer/no icemaker installed) 7 years old. Has been forming ice on bottom... (More)
Answer
no frost not freezing.not cooling as well...lg ref no frost.
Answer
The ice builds up in the bottom of the freezer and leaks down into the refrigerator portion the... (More)
Answer
low cooling,cannot produce ice.
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in , OK
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
