By the sound of this you have a degaussing problem! I think what has happened here is the degauss circuit has failed and the usual cause is the POSISTOR.
What you should try to do is switch the TV on, then OFF again and leave it for 30 mins before switching on again. When you have done this and the problem is no better, then contact a service centre who will cure the fault for you.
Alternatively, try to borrow a DEGAUSS COIL and with the set on, switch the coil on and by using a circular motion go around the screen of the TV moving backward slowly as you do it. When you are say 6 feet away from the screen switch the degauss coil off.
do you know of any brand of lcd tv that runs on 12v that has large screen bigger than 26in many...
(More)
do you know of any brand of lcd tv that runs on 12v that has large screen bigger than 26in many thanks J
i need codes to program my iwave jumbo universal remote. its black and says iwave at the bottom. i...
(More)
i need codes to program my iwave jumbo universal remote. its black and says iwave at the bottom. i really need the codes asap.
Sansui DTV2760 Auto turns off about 1 min after turned on. I can turn it back on but it turns off...
(More)
Sansui DTV2760 Auto turns off about 1 min after turned on. I can turn it back on but it turns off each time after about 1 min or so
Does anyone have the remote code for the Time Warner Cable UR5-8400A Remote for the ILO (Durabrand...
(More)
Does anyone have the remote code for the Time Warner Cable UR5-8400A Remote for the ILO (Durabrand TV)THANK YOU
