I have a DSL-320B modem set up in bridged Mode (running the latestfireware)attached to my DIR-655 router. I am attemptin to use the dynamic dns option to connect in, but am unable to remotely connect in. I have confirmed that the remote management is enabled. Is it possible to do with this set up?
D-link DIR-655 (A3-1.21) w/ Vista Home Premium, WPA2 security. Wii and TiVo connect fine but...
(More)
D-link DIR-655 (A3-1.21) w/ Vista Home Premium, WPA2 security. Wii and TiVo connect fine but MacBook connection times out when using built in AirPort. MacBook works fine with WPA2 hard wired and works wirelessly with WEP. Don't want to downgrade security to WEP. How can I make the MacBook talk to the router wirelessly?!?!?!?!
D-Link Dir-655 wireless works with XP and Mac both of which can connect using 11b or 11g. Now have...
(More)
D-Link Dir-655 wireless works with XP and Mac both of which can connect using 11b or 11g. Now have netbook which ONLY has 11g and it does not find the router (it doesn't show up on list of available networks). Is there a way to FORCE router to use 11g? What else could be wrong?
I can`t get the router to install.I have reset the factory settings and rebooted several times. what...
(More)
I can`t get the router to install.I have reset the factory settings and rebooted several times. what do i try next?
My problem is that my wireless network is not detected by my pc using an TEW-624UB Wireless N USB...
(More)
My problem is that my wireless network is not detected by my pc using an TEW-624UB Wireless N USB Dongle, It does detect other SSID's in my area. My ssid is not set to hide. And I can connect to my wifi network via my ps3 and also 2 laptops which have built in wifi adapters. I have tried plugging the TEW-624UB usb adapter to the laptop and checking if it displays my wifi ssid. but it is the same. It displays evey other network in my vicinity except my own. I figured it might be a problem with the usb wifi adapter and have since tried it with a Dlink DWA-110, but with the same results both on my computer and laptop it detects other networks accept my own. Mind you my PS3 and the Laptops using their built in wifi adapters is able to connect to my home wifi without any problems. I am using WPA-WPA2 as security and most of the other settings as default. I've tried changin the channel from 1 to 11 without any results. also turing off the wifi security does nothing.
