hi,
just stumbled upon you in a google search to reach d-link customer service...this is really cool! hopefully you can help...
i've had this problem a couple times before, but forgot how to fix it. i just got a new computer, so i need to reconfigure my wireless set up so that the modem and router use different IP addresses. i believe at the moment they are sharing the same 192.16.0.1, so that the wireless connection is dodgy and breaks after about 20 mins or so.
that said, it may break before i get your advice on how to fix problem. but i'm hoping for the best.
i'm using a MacBook Pro with a dsl speedstream modem and dlink router.
thanks!!
sarah
You will need to disconnect the modem from the router.
Then you will need to connect your computer to the router using an ethernet cable. (plugging into one of the LAN ports)
Next you need to log into the router control panel and change the IP address there. If your modem is giving out IP addresses like 192.168.0.5 then you will need to change the 3rd octet on the router to an IP address like this: 192.168.47.1
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,...
(More)
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas, access points)?
Stability and reliability are also critical
We use a comcast cable modem
Must support mixed environment - 2 Macs connecting wirelessly, 2 PCs (1 with a wired connection)
We all want to be able to share a printer (which will connect to router with a wired connection)
Network attached storage, media streaming - I'm not worried about these now, looking for basic connectivity. Though would be great if I could grow into this in the future...
We got a Belkin wireless. Plugged into computer via eithernet line. Computer is on a Verison...
(More)
We got a Belkin wireless. Plugged into computer via eithernet line. Computer is on a Verison wireless internet device, not a cable/DSL modem. We cannot get a signal to the router. How is we configure it for a wireless internet ISP service.
Rangemax wpn84, worked great until i forgot password and factory reset. Now wireless connection...
(More)
Rangemax wpn84, worked great until i forgot password and factory reset. Now wireless connection light wont turn on so i cant connect wirelessly. Default admin password will not work, no matter how many times i factory default
