Question about Maytag MER6772 Gemini Electric Kitchen Range
Fire goes out
Our maytag front load gas dryer lights, but the fire goes out after a few minutes. there is no problem with the gas supply. thanks
Check dryer vent. If it is clogged, will cause same problem.
Posted on Feb 03, 2008
    Sergeant:
  • 271 Answers
Your fail safe has gone you can get a local appliance second hand shop should help you as they all have there own gas men to fix all gas stuff give it a try
Posted on Jan 05, 2008
Stops and all the lights come on
Instructions
    • 1 Make sure the home's gas supply valve is turned on. Check your Maytag owner's manual to find the location of the dryer's gas shut-off valve. This is usually behind the dryer's front panel or in the back of the unit. Open the valve to allow gas to flow into the dryer.
    • 2 Open the lower front panel of the dryer to access the pilot light assembly. Press and hold the starter button as you light the pilot with a handheld lighter. If you have trouble getting it to light, release the starter button and wait a few minutes before trying it again. Once the pilot is lit, hold the starter button down for another minute to make sure it will stay burning.
    • 3 Close the dryer's front panel and run a test cycle to see if it is producing heat. Call a repairman to evaluate the problem if lighting the pilot did not restore the heat.
Jan 15, 2013 | Kenmore Dryers
My maytag model- MGD5740TQ0 gas dryer burner fires only for 10 seconds and stops; repeats every 2 minutes or so buy does not stay on long enough to dry load
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 22, 2010 | Maytag Dryers
I have a gas dryer that the igniter plug glows, but does not light the gas. One time when I had the front panel off the gas ignited and the dryer heated, but only burned for a minute then shut off. Now I...
with front off it will short cycle. If ignitor glows and then goes out without lighting, you have bad burner coils. The 2 black round things on burner assembly. Unplug unit then unplug coils and remove bracket with 2 screws. install coils and test.
Aug 27, 2010 | Dryers
Maytag Gas Dryer, heats for a few minutes, then flame goes out
Service Manual for Dryer similar to yours will cover disassembly and troubleshooting:
MDG5500
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 12001349
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires, explosion or death by asphyxiation.
Sep 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer - inadequate heat
Clean out your lint tray and hose. It sounds as if it is stopped up. The gas dryer automatically shuts off to prevent fires or overheating. The thermostat is probably O.K. since it will run for a few seconds each time.Let me know what you find out. Clean the lint trap first.
Jan 28, 2009 | Maytag Dryers
Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
Dec 13, 2008 | Maytag Dryers
Maytag gas dryer fires, then shuts down
may be the coils on the gas valve. there are 2. usually they need replacing when the ignitor glows but no flame
Nov 20, 2008 | Maytag Dryers
My maytag dryer does not get hot how can i fix it the model number is dg212 series 01
We bought this machine last year, converted it to propane & have loved it. All of a sudden there is no ignition ( fire). I have taken off the front & cleaned everthing I could see. Still no fire. I have check the gas supply, the drum is spinning, the only thing I think I heard last year right after it started and right before the "FIRE" was a clicking sound? What ever you might sugest would be greatly appriecated! Thank You, Don Wagner Jr @ SmoothSeal1@aol.com
Jan 12, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MER6772 Gemini Electric Kitchen Range Logo
60 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
