Question about Mitsubishi WS-65807 65" Rear Projection Television
TURN TV ON AND THEN IT CLICKS OFF
WHEN I TURN ON THE TV, 2-3 SECONDS LATER I CAN HEAR IT AND IT CLICKS OFF. WE HAVE REPLACED COIL RELAY AND THAT DOES NOT CORRECT THE PROBLEM. WE ALSO PURCHASED A REPAIR MANUAL BUT IT JUST GIVES THE PARTS DIAGRAM AND SCHEMATICS OR LAYOUT OF THE PARTS...NOT MUCH HELP. CAN YOU PLEASE TELL ME WHAT TO DO TO FIX THIS PROBLEM OR HOW TO CHECK SOME THINGS? THANKS SO MUCH, MEGAN
  • TravisHetzer Jan 10, 2008
    I have the same problem same tv.
  • Mitsubishi Master
  • 8,617 Answers
Look through the parts index for the horizontal output transistor and the low voltage regulator transistors. Check these for either shorted or open, and also this model is famous for bad capacitors . If you need info on how to check the transistors please refere back to me and I will try and explain how you go about doing it.
Posted on Jan 05, 2008
6ya staff
SOURCE:
Started motor fine a few minutes later it died and would not start again had wife crank over while i look in carb no gas spraying into carb prime with gas and it would run for a sec then die again...
When you state "carb" I assume you mean TB as it should be Throttle Body Injection, unless it was converted.
You should be able to hear the fuel pump in the tank prime for about 2 seconds when you first turn the key on. May have to get your helper to remove the gas cap and listen through the filler.
If you don't hear a buzzing sound then check the relays on the firewall. You can turn the key off, wait a couple seconds and then turn the key on and have your helper listen and feel for the relay that clicks.
Or look for the wires,
The relay will have a dark green/white from the ECM
Grey is power to the pump when the relay is enegized.
Orange is hot at all times. It comes from the ECM B fuse. Should check that as well if not done so.
Black/white is a ground.
Now most likely if your relay clicks when the key is turned on then its all fine and the fuel pump has gone out. The oil pressure switch also enegizes the pump when there is oil pressure.
Oct 04, 2011 | 1987 Chevrolet S-10 Pickup
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Toshiba Color TV Relay clicks slowly. TV does not come ON.
Electrolitic Capasitors in the power supply going or being bad will cause this. At some point a low value resister also will start to run hot or burn up. I believe it it a 16v 1500 uf cap near the relay. I would also replace any 10uf 160v caps in the powersupply too.
Hope this Helps,
Skyassoc
Jun 17, 2009 | Televison & Video
Power to Amp but no lights and does not switch on
(1)When the unit is switched on the relay clicks in,but no sign of life, and then five seconds later the second relay clicks on/off don't know which. This symptom is DC outputted to speaker terminals. Check any DC at power amp stage output.(2)Must have blown up.
Positive. If Caps blew, your amp shutted itself down within 5 seconds due to + & - power supply creating an unbalanced +B & - B voltage not allowing your amp to turn on.
Oct 05, 2017 | Optimus STA-3500 Receiver
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
Nov 06, 2008 | Televison & Video
Subwoofer powers up and clicks off after 2 seconds, no sound, ever.
if you know what a transformer is, and if you have a multimeter, i suggest you to go ahead andcheck the transformer,
Nov 05, 2008 | JVC TH-C5 System
Haier 42EP24S
Welcome to the club.
Repair kit TV-3940-01 will solve the problem. Unfortunately is is very difficult to find.
Rich-Tech has a kit (6871VSNB03E) that replaces the three boards but it does not include the EEPROM. I do not know how long the repair will last if the EEPROM is not replaced as part of the repair.
Aug 23, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Lg tv will not turn on, red light
i think your bulb is shot must be replaced
Dec 17, 2007 | LG 42PX4DR 42 in. Plasma TV
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
