I'm a plumber and was looking at a friend's Ariston Microgenus 28 kW combi boiler today. The problem...
(More)
I'm a plumber and was looking at a friend's Ariston Microgenus 28 kW combi boiler today. The problem is the DHW comes out tepid, then within a few seconds of the burner igniting, the temp indicator lights on the front panel show 80 deg and the burner cuts out. The water goes cold again, the supposed temp drops to 60 and the burner fires again- but again only for a few secs til the lights show 80 again. I removed the temp sensor and cleaned it, but no difference. Does anybody know what value in ohms the sensor is supposed to be giving, so I can test it before buying a new sensor?
i have hot water for a few minutes then it turns cold i have replaced the bottom t-stat should i...
(More)
I HAVE HOT WATER FOR A FEW MINUTES THEN IT TURNS COLD I HAVE REPLACED THE BOTTOM T-STAT SHOULD I REPLACE THE TOP ONE
My Ariston combi boiler constantly looses pressure but I cannot find any leaks and it fails to give...
(More)
My Ariston combi boiler constantly looses pressure but I cannot find any leaks and it fails to give hot water. It gives about 30 seconds of warm water and then runs cold. Ariston Engineer came out last year and said is was dirt in the system, had full flush (2 in fact) as advised by them but did not solve the problem. Ariston swear there is no problem with the boiler - if it wasnt a few years old and still under guarantee I would dispose of it and have a Worcester Bosh
when i turn my faucet on, the water runs lukewarm, then hot for 15 seconds, then it turns really...
(More)
when i turn my faucet on, the water runs lukewarm, then hot for 15 seconds, then it turns really cold. I have a propane gas/water tank combination, any troubleshooting I can do before I hav eto call someone
my chaffoteaux britony 80e combi boiler will not fire for hot water but will fire for heating with...
(More)
my chaffoteaux britony 80e combi boiler will not fire for hot water but will fire for heating with hot tap open
