Dennon DRA625RA Left speakers sometimes cut out and leave just a high treble sound. Other times its a full sound. It is not the speakers or the speaker wire. Is this easily repairable? Unit is around 20+ years old, but otherwise works great. Thanks, Thom
please check the input connecetor could be the losse conact with the wire some times it happens with this type of sound try to play the system and move the connector if the sound trun go replace the input cor
i have 6 speakers c' sw' 2front 2 back. i can not here the c' 2 back. when i sreching with ch chanel...
(More)
i have 6 speakers c' sw' 2front 2 back. i can not here the c' 2 back. when i sreching with ch chanel i dont see the c and two back speakers. at the biggning there was no problem. is there a manuel in hebrew. thank you very much
Same problem here, red light is on the volume knob. Clicks to turn on but the UI does not light up. ...
(More)
Same problem here, red light is on the volume knob. Clicks to turn on but the UI does not light up. Worked last night, simply turned it off before bed. Next day it will not run on. Power cycled it etc....
