Kenmore 16322
Problem for Kenmore 16322
Model 141.163211 Kenmore BBQ Grill. Burner tube
By drbrown49 on Nov 07, 2009
Model 141.163211 Kenmore BBQ Grill. Burner tube ignites then after a few seconds flames ignite behind control panel - melted knobs. A year ago same problem. Removed all parts and cleaned, installed new requlator & hose - This fixed it. This time I removed and cleaned all parts again but did not replace requlator - No fix.
Solution #1
posted on Nov 07, 2009
Not Rated)
fredy2
Rank: Wiz
Rating: 84%, 359 votes
It sounds like sealant may need to be used on connections. Use appropriate one for gas fittings.
Noting where the leak is occuring is important. Another possibility is the fuel is being somehow "jetted" from a hole or orifice in a burner tube to the area behind the control panel. These are hard to see what happens first when it does happen.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 16322
Questions and Unsolved Problems for Kenmore 16322
Do you recommend Kenmore 16322?
Answer
Answer
Hi anyone my big G.Forman just stop working the degree dots are on. You can't put anything into the... (More)
Answer
Regulator frequently freezes and cuts off gas supply
Answer
I have a Char Broil CB940 charcoal grill that I need to replace the front locking casters on - where... (More)
Answer
We just filled our 250 gallon propane tank to the maximum capacity ( I believe it is at 80%)... (More)
Answer
The igniter in my Kenmore Enviro Plus 80 Furnace is not going on.The furnace is just huming but its... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 16322:
Top Grill and Smoker Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Grill and Smoker Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
