Question about E-Machines eMachines Desktop PC
Start up mode
Computer comes on but wont go past the screen saying ,safe mode,last known good configuration,start windows normally.if i try to enter any of those it just restarts and goes back to that screen.
  • 1 more comment
  • carl porter Jan 06, 2008
    ty ill try it
  • carl porter Jan 07, 2008
    thank you
  • Anonymous Mar 19, 2009
    same exact thing. just keeps restarting then apologizes when it cant boot it
  • 589 Answers
It may be a corrupt MBR, or possibly the boot partition. If you have an XP disk, try to get into the recovery console.
  1. Restart your computer with the Windows XP Setup disk in the CDROM drive.
  2. If you are prompted to press a key to start the computer from CDROM, do so quickly. Otherwise it may try to boot from the hard drive.
  3. After a few minutes, you'll see a prompt to press the R key to start the Recovery Console.
  4. When Recovery Console starts, it will prompt you to enter a number corresponding to the Windows XP installation that you need to repair. In most cases, you'll enter "1" (which will be the only choice). If you press ENTER without typing a number, Recovery Console will quit and restart your computer.
  5. Enter your Administrator password (if you have one) If you don't enter the correct password, you cannot continue.
  6. At the Recovery Console command prompt, type fixmbr and then verify that you want to proceed.
If that doesn't work, try the above procedure again, but substitute "fixmbr" with "fixboot". Good luck!
Posted on Jan 07, 2008
I'd just do a factory disk reload for all your drivers and programs. Sounds like ddl are missing. Good luck.
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
My laptop wont come on a screen keeps coming up asking to repair or start windows normally i have tried both without success
When was the last time you were able to use your computer?
Did you installed any software recently in your computer?
Try pressing F8 on startup and use the Last Known Good Configuration. May be that will help.
Feb 28, 2011 | Toshiba Satellite Laptop L655S5150
I have an Acer Aspire One with Windows XP and when I turn it on a black screen comes up saying "We apologize for the inconvenience, but Windows did not start successfull..." Then it gives me a list of...
Try to use the last known good configuration the issue should be fixed.. If afforadable try to get a external DVDdrive.. If not try to get one from friends.. Nothing is working.. call acer they will take your computer and reinstall the OS ....
Sep 20, 2010 | Acer Aspire One PC Notebook
When i turn it my eee pc on it pops up to where it says windows and thats as far as it will but it will only load up in safe mode
Try restarting your notebook and hit the "f8" key after you see the first screen come up. Keep hitting the F8 key until you see a menu that says "start in safe mode" start in safe mode with networking......
Start in last known good configuration....Start windows normally.
Try using Start in last known good configuration.
Hopefully, that will solve the problem that is hanging up your windows from starting.
Brian
Mar 01, 2010 | ASUS Eee PC 1000H Laptop
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
Laptop Will Not Boot
chose start windows normaly
Apr 14, 2009 | Acer Aspire One PC Notebook
Laptop won't comeback on
Try safe mode.
On safe mode return the computer to an earlier date configuration.
At some point will ask if you want to do that. And say yes.
Make sure that if for some some reasons it asks you to restore the computer to factory settings, you should say no. I hope you can do this.
Mar 31, 2008 | Toshiba Satellite 1405-S151 Notebook
Boot-up
dot.gif How to load last known good configuration. Question: How to load last known good configuration.
Additional information: The "Last Known Good Configuration" option was first introduced in Microsoft Windows 2000 and is available in all later versions of Windows including Windows XP. This feature enables a user to load the last working version of Microsoft Windows. This is a great step to try when trying to fix issues with a computer not being able to load into Windows.
Note: Users able to open normal Windows XP mode and who wish to restore their version of Windows to an date before the last known good configuration may also wish to consider doing a system recovery in Windows. Additional information about how to do this can be found on document CH000589.
Answer: To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key. Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP safe mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the safe mode screen.
Please select an option: Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows. Will running the Last Known Good Configuration delete anything? No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Dec 06, 2007 | Computers & Internet
E-Machines eMachines Desktop PC Logo
85 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
