Refrigerators
Problem for Kenmore Refrigerators
Generic problem for all Kenmore Refrigerators
Water not making it to ice maker
By dwebber1955 on Nov 07, 2009
water not making it to ice maker
Solution #1
posted on Nov 07, 2009
Not Rated)
localwonder
Rank: Guru  Refrigerators  Expert
Rating: 92%, 2861 votes
HI. I would advise to inspect the water valve assembly. This will be the likely culprit.(Make sure that the lines are not frozen, and the water filter, if equipped, has not reached its filtering limit, before proceeding)
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Was this helpful?
Yes
No
Popular Solutions for Refrigerators
Questions and Unsolved Problems for Refrigerators
Answer
I am thinking of buying a used 2005 GE side by side fridge model GSS25XSRCSS. Any experience good... (More)
Answer
the samsung four door quattro refrigerator
Answer
water and ice bottom of freezer
Answer
My frigidaire electric dryer will not engage when the switch is turned on. All I get is a buzzing... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Kenmore
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
