Question about Refrigerators
Broken ice maker
We have a side by side whirlpool gold refridgerator with an ice dispenser in the door. The unit has been producingice fine for the last three years. It has now quit making ice and appears te problem is it is not filling the ice maker tray with water.
  • 1 more comment
  • Anonymous Apr 26, 2008
    three year old ,also not filling the tray either.....
  • jkepner486 Oct 27, 2008
    ice maker is broken ...the piece that grinds the ice
  • Anonymous Jan 05, 2009
    Our ice maker has been working fine for over three years. Yesterday it quit producing ice. After investigating it appear the tray is not filling with water. I check the water filter and it is time to order one according to the light on the refrigerator side. The water dispenser is working fine. It must be an electrical problem. I'm quessing
  • 90 Answers
Make sure icemaker cycles. If it is most likely bad water valve
Posted on Jan 05, 2008
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker stopped making ice, it just stopped. There is nothing blocking the outlet, no debris. The water dispenser still works fine but the ice maker is not working. I have a whirlpool 2665 refrigerator....
your ice maker unit is gone bad if you have warenty get them to replace the ice maker if not you need to do it :(
its coast +- 120$ :(
911service today . com
Jan 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GS6NBE side by side ice maker works fine but the ice dispenser doesn't. I can hear a sound and a click when I push it and the dispenser flap works but no ice will come out. Water works fine.
The four prong (flat) plug to the ice maker (in the freezer compartment) in my Whirlpool Gold SbyS Refrigerator; should I be able to test for 120 Volts with a tester, should this plug be 'HOT"?
Sep 04, 2009 | Whirlpool Freezers
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold moder GC5SHEXN503 side by side-ice maker not producing ice anymore--water dispenser works fine--laser lites seem ok---no ice jam--no water filling ice molds
Put some water in the ice maker and see if it will kick a batch out. If it does make a batch but does not make any more then replace the water valve. NOTE: the water valve is a dual purpose valve that supplys water in the door and supplys the ice maker. If the ice maker does not kick out a batch then something is wrong with the ice maker.One easy component to replace is the ice mold thermostat.
Feb 20, 2009 | Whirlpool GD5SHAX Side by Side...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Side by Side Refridgerator GS5SHAXNTOO "Not" making Ice
this is a very broad problem. you have issues with your ice maker. it could be the solenoid that supplies water to it. it could be turn off, it could be the laser sensor malfunctioning. it could be the receiver of the laser. it could be the gear that harvest ice is froze up. or the heater to melt the ice if it has one has gone bad. or it could just be a stuck ice that would not come out of the ice maker.
you can remove your ice maker, thaw it up if there is ice in the tray. then install it back and observe.
tnx 4 using fixya,
drcool
Oct 31, 2008 | Whirlpool GD5SHAX Side by Side...
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold ice maker problem
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
517 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
