Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
When I pulll the knob on the washing machine, their is no water not running out
When I was getting ready to pull the knob on the washing mashing tto start the cycle, there was no water running out in the steel basket. What is causing that problem?
  • 589 Answers
Can you hear it "clicking" when you pull the knob (not the knob sound itself, but the water solenoid itself)?
If you can hear it, then make sure the machine has a water supply (hot / cold). You would be surprised at how many people accidentally turn off the water supply and forget about it.
Try changing the wash settings to cold/cold, etc (the opposite of whichever one you're using now) and see if it will fill.
Let me know the results, and I can help you further.
Posted on Jan 08, 2008
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Ariston a1124 knob keeps turning
My machine stopped before/on the spin cycle and the knob was going round and round. I pulled the machine out, emptied the water and the washing and got ready to strip the weights out so I could get it out of the house and to the tip. I tried Jason Harris's tip and so far so good! The machine appears to be working normally. I have it on an empty trial wash. What a star that man is ! Julie
Aug 06, 2012 | Washing Machines
My Blomberg dishwasher will not stop draining once all the water is out. It is at the beginning of the cycle and it's like its stuck and won't move on to the next part of the cycle to bring water...
Doug Smith\'s solution of Oct. 20, 2008 worked for my Blomberg Dwt57500ss model.
Removed small filter basket by pinching 2 tabs inward at the top of the basket. Turned larger basket counter-clockwise by hand and lifted out stainless steel screen. Used wet/dry vac to suck all the water out. The anti-flood switch reset itself. Turn power back on to unit, and pressed start. Then pressed program I wanted to use and reset button to start machine. Worked immediately and started washing dishes.
Sep 05, 2011 | Blomberg Dishwashers
WHDSR209DWW on/off button will not engage to spin the cycle selector dial
The cycle selector is not engaged onto the timer shaft. Need to remove the on/off knob by removing the plastic "U" clip. Remove the cycle selctor knob and check that the steel spring clip on the selector is fully seated. Re-install the cycle selector onto the timer shaft aligning the selector key with the with tthe notch on the timer shaft. Re-install the on/off knob.
The cycle selector and on/off combination is a poor design. Users press the on/off knob in and turn clockwise to set the wash cycle. If you're not gentle this action wears the teeth on the timer shaft and the user has to press harder and harder to set the wash cycle. This pressing causes the cycle selector to be pushed off the timer shaft and you can no longer operate the machine.
VERY IMPORTANT:
Stop using the on/off knob to set the wash cycle. Press on the cycle selector to set the wash cycle. Use the on/off knob only for starting or stopping the machine. Don't press or pull too hard on the on/off knob or you will wind up pushing the cycle selector off the timer shaft.
Jan 12, 2010 | General Electric WHDSR209DWW Top Load...
Kenmore 600 with atc. water temp change
to change water temp when a cycle has started, pull the knob and reset the water temp, then move the dial to the desired setting. push knob in. resolved by trial and error!
Nov 05, 2009 | Maytag MAV5920E Top Load Washer
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Fabric softener cup on Maytag Neptune washer is full of fabric softener after the cycle. Checked valves in output mode. Both the main and the bleach valve turn on and dispense water, but no water dispenses...
Hi. your problem is actually a rather complicated one.
Timer and selector switches The timer switch is usually the largest dial on the main control panel. It can be either a mechanical device much like a simple clock, or completely electronic with just a digital readout.
The timer runs the washing machine in a pre-determined pattern. It provides the electricity to all of the washing machine components at the correct time and for the correct length of time.
The Start switch is usually part of the timer knob. When you set the timer to the proper cycle, you either pull or push the timer knob to start the cycle.
The selector switches or knobs vary from machine to machine. Most washing machines have one or several switches or knobs on the control panel besides the Timer/Start switch. These let you adjust certain settings; for example, the water temperature, spin speed, timer cycle, and so on. Normally, the washing machine completes the cycle selected on the timer, regardless of how you set these switches and knobs.
Jul 14, 2009 | Maytag MAH2400A Front Load Washer
GE Profile Harmony not draining wash load
HOW OLD IS YOUR WASHER? IT SHOULDN'T COST THAT MUCH TO REPAIR IF YOU CAN'T FIX IT. IT SOUND LIKE YOU MIGHT HAVE A PROBLEM WITH THE BELT OR MOTOR COUPLING. I DO NOT WANT TO TELL YA WRONG. I JUST HOPE YOU CAN GET YOUR PROBLEM FIXED. TRY TO CALL A REPAIRMAN SOON. GOOD LUCK.
RODNEY
Mar 27, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
