Home | Poulan | Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin | Carburator settings
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Problem for Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Carburator settings
By stanbruce on Nov 07, 2009
carburator settings
Solution #1
posted on Nov 07, 2009
Not Rated)
just-ice
Rank: Wiz
Rating: 88%, 16 votes
If you have played with them the only way is to get it going pretty well is" ....
find the idle screw - usually larger - and turn in 1/2 a turn - hopefully that will keep it running - then find the 'slow' running screw turn it in until it stops then turn out 1 and 1/2 turns. Leave the fast one alone.
Get it started then adjust idle screw so its faaster if need be.,, now slowly turn the 'slow' screw in then out say 1/2 turn and listen for it either speeding up or slowing down leave it at the point where it sounds ok and try giveing a few 1/2 speed rev ups. If it goes back and idles as before - leave it.
The fast screw... (first make sure your exhaust outlet is totally unblocked - the slightest restriction here will cause it to never run right at high speed). Start it up and then try full throttle - same thing as before try adjust the fast screw first in a little then out until it runs well at what seems the faster speed it can - then check that it accelerates well from idle to full speed. If not adjust it a little more until it does.
Once it will idle ok and return to idle and also run full speed, then you can back off the idle screw until it will idle without the chain racing arond the bar.
Bear in mind th chain wil be racing around while you adjust it so keep fingers kids and idiots well away..because you are adjusting it with that chain moving..
Was this helpful?
Yes
No
Popular Solutions for Poulan Wild Thing 2375 18" Gas
Questions and Unsolved Problems for Poulan Wild Thing 2375 18" Gas
Do you recommend Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin?
Answer
Answer
I have the same problem as gaffierok except it's a drive sprocket for an electric mastercraft... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Poulan Wild Thing 2375 18" Gas...:
Top Chain Saw Experts
Rank: Guru Guru
Solutions: 3943
Experience: ten years experience,school trained,own business
Ask Me
Find more Chain Saw Experts
Top Garden & Power Tool Repair
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
