is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
salde386 is
correct. I had the same issue with my Kenmore 90 series. My dryer would
get hot for about ten minutes and would not get hot again. I changed
the gas coils/solenoids and that fixed my problem. Hope this helps.
Here is a pic of where are they located -->
http://ww2.justanswer.com/uploads/applsvcgirl/2008-01-22_173331_Gas_Burner.jpg
Comments:
Nov 10, 2009
- salde386 is
I have a gas dryer that has a bad thermostst how can it be replaced Do 110 dryers use more...
(More)
I have a gas dryer that has a bad thermostst how can it be replaced Do 110 dryers use more electricity than the 220, are they safe
I have a kenmore dryer model #110.63942101. The drum will not continue spinning once I release the...
(More)
I have a kenmore dryer model #110.63942101. The drum will not continue spinning once I release the button. (It spins as long as I hold the button) The timer and heat seem to work and the buzzer goes off after the appropriate amount of time. I am hoping that this is something that I can fix myself. Any ideas?
