Question about Nespresso Aeroccino Automatic Milk Frother
Not making froth
After only 1 week using approx 4 times a day, my Aeroccino has stopped frothing milk. Although the rotor still revolves it appears to be slower.
regards
Derek Williams
  • 13 more comments
  • stickney Jan 10, 2008
    only frothed one time...now only steams the milk. what are we doing wrong??
  • lizzie9 Mar 06, 2008
    Have same problem - frother not frothing!! Worked beautifully for two months then one day stopped. Help
  • Anonymous Jun 01, 2008
    One week and not frothing. sounds like they have a problem
  • posnada Jun 05, 2008
    I have just opened my new Aeroccino and it does not froth. It does heat the milk. Regards, posnada
  • dsou Jun 21, 2008
    the same a new Nespresso Aeroccino milk frother - used for two weeks. It heats the milk but does not froth
  • kcmf44 Aug 10, 2008
    Almost from the onset, my frothing element has not worked. The milk is heated    but no frothing!  Help! Kathi Cohen
  • vittoriavh Aug 28, 2008
    the problem began about a week or two after I purchased the machine..it just stopped frothing. I find that using fresh organic half and half minimizes the problem, but I believe this product just does not last! it is a too-good-to-be-true product
  • Anonymous Dec 23, 2008
    After one week of great froth it stopped working. Is it really that bad? I will leave it upside down to see if works tomorrow.
  • Anonymous Dec 25, 2008
    I have the same problem. Worked perfectly and stopped making froth after a couple of months. Am now trying the invert trick to see whether that helps. Bit strange though the product should work also when left on the base.
  • Anonymous Jan 17, 2009
    I called Nespresso to complain about the lack of frothing and they sent me a new, upgraded one! Customer service is the best!!!
  • thepappies Jan 17, 2009
    second one in 6 months just not for for purpose will se what they offer
  • Anonymous Jan 18, 2009
    We recently purchased Nespresso Aeroccino (30.12.08). Frothed milk PERFECTLY for ten days ( approx. 2 cups per day) but now just heats milk NO FROTH.
  • shoeys Mar 09, 2009
    My aeroccino (purchased 23/12/08 at Castle Hill Sydney) worked reliably for about 2 weeks making 1-2 cups per day. From then till now 10/3/09 it has been intermittent - only makes a usable froth in about 1 in 7-10 tries. Most times it just heats the milk. I have compared side by side with the same milk a friends unit, an 18 month old aeroccino with LOTS of hours use, and theirs works fine every time. My frother spring spins well and seems very magnetised, but for some reason it just doesn't work properly.
    Who do I contact for a replacement? the shop I bought it from or the distributor? Anyone got a contact?
    Cheers
    Jeff
  • Deepti May 26, 2013
    My rotor does not revolve. Milk gets hot but does not froth! Help pease!!
  • Anonymous Mar 14, 2014
    Not frothing is intermittent and seems to relate to the milk I purchase. Do some brands not froth? I always use full fat milk
Had the same problem, but called Nespresso. Their tech suggested the following: 1) always leave off the base - will stay on even if button not pressed 2) invert the Aerocinno for 24-48 hours to "reset" the thermostat in the device. I began leaving the base plugged in, but immediately after using and cleaning (don't get ANY water in the bottom of the machine!), I invert the Aeroccino and leave it that way. My machine began making great froth with any tyoe of milk, and continues to do so a month later -
Sounded crazy to me initially, but it works.....Never returned the device, and no need to do so now - Good luck!
Posted on Oct 24, 2008
Nespresso states that leaving the Aeroccino on its base while it is plugged-in to the wall, will cause it to short-circuit (because there is no off-switch on the base, it is continually feeding full power to the frother), and the result is that it makes only warm milk. Replacement is the only solution...I hope you are still under warranty.
Posted on Aug 09, 2008
I had to replace the thermal fuse, but mine works now. The thermostat is on a spring, so I don't understand how inverting it will help. I can certainly see how leaving it off the base is important. Just know that power is flowing to the base, so if you have kids, keep away. If they start shoving metal inside, it would be similar to an outlet.
Posted on Jan 20, 2009
  • 1 more comment
  • Max G5
    Max G5 Aug 22, 2014
    My Aerocinno had a broken fuse that shuts of at 108 oC. I replaced it with a fuse 110 oC 4-5 Amp. Now the frothing shuts of later and the milk is warmer and more consistent.
  • Tomeu Rossell Pons
    Tomeu Rossell Pons Oct 30, 2015
    Hey guys. I think that the thermostat (the one mounted on a spring) in mine's broken, because the result is pretty much the same with the thermostat connected to or disconnected from the board (red flashing light after 1.5 seconds). The aeroccino works great in cold mode.
    Can you tell me where to get a replacement? May I find a replacement at Amazon (I live in Spain)?
    Also, it could be the thermal fuse, but I don't even know what that looks like or where it is located on the board. Just in case, Could you tell me how to identify it and where to find a replacement?
    Thanks in advance.
    Thanks in advance.
Silly man, try skim milk. The lower the fat content, the frothier it gets.
Posted on Jul 12, 2008
Mine works much better with fresh, full fat milk. Not as healthy but much nicer!
Posted on Jan 24, 2008
The milk really matters!
Posted on Aug 05, 2008
Not frothing
try contacting the manufacturer thru their website . all man made things do fail eventually
Dec 26, 2017 | Nespresso Aeroccino Automatic Milk Frother
My nespresso aeroccino automatic milk frother is spinning and heating up but not frothing milk
I found that switching to a different milk solved my issue. It worked well with whole milk, but when I used Trader Joe's two percent organic it would not froth after .multiple tries. I borrowed a neighbor's creamer and it worked again.
Oct 13, 2012 | Nespresso Aeroccino Automatic Milk Frother
Nespresso Aeroccino 3 does not heat and froth
I got mine today exact same thing happens... only blue does not warm AT ALL
Aug 26, 2012 | Coffee Makers & Espresso Machines
Aeroccino frother won't turn back on after we get some froth and still more milk in container.. takes a long time to be able to activate again.. using Almond milk could be the problem any suggeest
My Nespresso Aeroccino often would not heat or froth multiple times after one use. I called Nespresso, they have excellent customer service, and was told to rise the inside (careful not to get the outside button or electric elements wet) of the Aeroccino with cold water a few times and to retry. Works like a charm!
The customer service is the best I have encountered in a long while, give them a call, it will make your day they are so pleasant and helpful!
Feb 18, 2012 | Nespresso Aeroccino Automatic Milk Frother
My nespresso machine won't froth the milk
Brand of milk definitely matters... Here in Canada I used Sealtest 1% when I first used it and the froth was thick light and luxurious. Then one week picked up Neilsen 1% and found it produced absolutely ZERO froth. Back to Sealtest...back to froth. Milk brand matters....but don't know why.
Jan 14, 2012 | Nespresso Aeroccino Automatic Milk Frother
The frother doesn't froth. I start with cold milk fill it to the hot froth line and push. The red circle lights up and whirls around, but when it stops there is no froth
I have tried tilting mine slightly, just a 20c peice under one edge of the base put enough of a lean on it to make the milk froth. Shouldn't have to do this, I know. I am having similar issues becasue I don't think I should have to alter the unit. Mine is 2 weeks old.
Feb 15, 2011 | Nespresso Aeroccino Automatic Milk Frother
Aeroccino deosn't make froth
Our aeroccino worked fine for 2 years and suddenly it didn't made foam anymore. We tried the "inverting trick" without much success. We contacted Nespresso and they suggested switching from regular fresh milk (we used 2%) to UHT milk (harder to find in US) and to use it cold and freshly opened. So we tried that and it works.
Hope this solution works for you too
Aug 08, 2009 | Nespresso Aeroccino Automatic Milk Frother
Aeroccino Overflows
As a Nespresso demonstrator I've had this question many times- use the black plastic wand for light foam- can use to max line. Using the wire whisk wand for heavy, cappacino foam and fill only to bottom line. This wand uses more aeration to achieve foam density- causing more pressure and your leaks. The wand stored inside the lid doesn't have anything to do with function of the aerrocino.
Jul 06, 2009 | Nespresso Aeroccino Automatic Milk Frother
Aeroccino does not heat
Try descaling, if the element is covered with scale it wont produce enough heat and pressure.
The machine is Krups, and therefore should be covered with one year warranty. Call the number listed on the user manual, or find contact from websites below:
Coffee & Espresso Machines - Small Domestic Appliances - Krups
Home - Krups UK
Oct 06, 2008 | Nespresso Aeroccino Automatic Milk Frother
Nespresso Aeroccino Automatic Milk Frother Logo
7,221 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
