My Acer just stopped reflecting the DVD/+ hardware. It looks like the drivers are uninstalled. It is no longer visible in my Computer's window. what can I do?
I mean you can access the hardware or removable where anywhere in the laptop.
When you insert a disk, the drive will run with an activating noise but not showing anywhere in the laptop atall nor doing any further thing. if I try to access it through my computer or the control panel, I will not see a sign of it in the computer section of my laptop.
The laptop only shows the hard drive C and the D drive which is the Acer Recovery without any other drive showing
Maybe is you DVD drive dead, but try this,I think that only one screw take a DVD drive. Relase the screw, and just push DVD drive. Turn on laptop without DVD drive and turn off. Put you DVD drive inside laptop, and try again turn on.
If you still have a problem, dont lose you hope, I see that problem on many laptop, where is DVD drive OK.
Sounds like the data connection to the drive has been lost. The power connection is still present, though. i would try to remove the drive, and with a light try to look at the connectors on the inside of the computer and also at the back of the drive. If nothing is obviously wrong, blow the area out with air and plug it back in. If this doesn't fix it, start looking for a new DVD drive for the computer. Good luck!
unable to open my Toshiba P200 Notebook's desktop. The computer boots up ok but the desktop is blank...
(More)
unable to open my Toshiba P200 Notebook's desktop. The computer boots up ok but the desktop is blank I can access programmes and sites via Task Manager only
the top of the case, right above the opener is seemingly delaminating. I have had the computer two...
(More)
the top of the case, right above the opener is seemingly delaminating. I have had the computer two months
I got an acer aspire 5550 notebook. That day when i power on using the battery, it's run ok. After a...
(More)
I got an acer aspire 5550 notebook. That day when i power on using the battery, it's run ok. After a while, i plug in the power supply, then the notebook turn off and can't turn on. I tried unplug the power supply, running on battery, oso can't power on. I tried running using power supply without battery, oso can't power on. and wat can i see is the Green LED at the power supply there. It is blinking, when i plug into the notebook. The LED light become stable when i unplug it from noteboook.
On my Acer Aspire 5810T,there's a white screen on start up,then after 10 mins or so,it goes to...
(More)
On my Acer Aspire 5810T,there's a white screen on start up,then after 10 mins or so,it goes to password screen as normal....then a small box called 'Project 1' which says 'Run Time Error '75' Path/File Access Error comes on the screen...... are they connected....???
