Question about Hampton Bay 24002 Ceiling Fan
Ceiling fan lights do not work
The ceiling fan works fine, but the lights do not.
I had broken light bulb in the lighting can. After I removed the base and turned on the lights (I use the wall switch; not the pull cord), I heard a noise and tripped the fuse. After I reset the fuse, the lights do not work. The electrical connections in the lighting fixture seem OK. What is the most likely problem?
Thank you
  • davez22 Oct 05, 2008
    I don't know what Hampton Bay model of ceiling fan I have--it's white with gold accents. The light is not working on it. The fan is working. I thought it might have been the switch but when I went to home depot the guy there told me to turn off the circuit breaker and with the switch removed connect the lines that run into the switch to bypass the switch and see if the light comes on. It still doesn't work. It must be the light kit that's defective. How do I determine what model of fan/light kit that I have to order? Do you agree that it's the light kit that is defective?
    Problem Solver:
  • 4 Answers
You may have shorted out the light kit. Did you remove the other bulbs and put in new ones? They may have all blown when you heard the noise. Try that first, and if it still doesn't work, you may have to buy a new light kit. They are not expensive, and you can buy one without the glass bulb holders or cans, whatever you have. Then you can still use yours after you install the new light kit. Good luck!
Posted on Jan 07, 2008
I need a replacement LED light bulb or kit for my Hampton Bay fan model number AM215-BN. Where can I get one?
http://www.homedepot.com/b/Lighting-Ceiling-Fans-Ceiling-Fans-Accessories-Ceiling-Fan-Parts-Light-Kits/Hampton-Bay/N-5yc1vZc5t3Zp4
Aug 14, 2016 | Hampton Bay Dryers
Hunter ceiling fan fan is working but lights are not
Make sure light wire is connected at the ceiling & at the bottom. Otherwise it's probably the receiver. 1-888-830-1326 ( Hunter parts )
Jan 05, 2013 | Hunter 52" Ceiling Fan With Light And...
I have Hunter ceiling fan / light. I installed it. It worked fine for a little while, than one bulb blew out, then a second bulb blew out, now none work. Yes I repaced all the bulbs, still don't w
I would check with a voltmeter if you can safely to verify power at the light socket using an adapter to a plug in it. If you can not do that, with power off you may want to make sure that the socket contacts are good and clean. Sometimes they can become tarnished badly.
Oct 10, 2012 | Hunter 23852 Classic Original Ceiling Fan
Hampton bay ceiling fan stopped lights work
you can test the light switch by temporarily hooking up the light bulb to where the fan normally goes ....the bulb will only work on the highest speed setting but can prove if the switch is bad or not . turn power off before woking in there ... if you know someone with a volt meter then they could quickly test the switch for you .. they can also test the motor for continuity .. .. most of the time the trouble is simply bad connections inside the wire nuts ... like insulation not skinned properly or wire not in the wire nut properly ..you can remove and inspect each connection (power off of course) ... sometimes there is a seperate power line for the fan and light ... so they can be independently controlled externally ... thats not needed when the pull chains are the only off on method ...
Apr 15, 2010 | Hampton Bay 52 In. White Redington...
Question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
Ceilng Fan light fixture-metal clasps have broken off
For Hampton Bay ceiling fan replacement parts!!!
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
Nov 25, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Ceiling fan lights won't work
Possibly, your switch has a short in it.Outside of that, it may be a broken wire somewhere. Hope this helps. Good luck.
Aug 25, 2008 | Aloha Housewares (93645) Ceiling Fan
Hampton bay model 55295 fan works, light doesn't
Did someone give you advice on this? My fan is doing the same thing. Fan works fine, but the light does not. Looks like the electricity is not making it down to the ballast - trying to figure out how I can repair it.
May 27, 2008 | Hampton Bay (261025) Dual Mount Ceiling...
You have a dangerous electrical situation call an electritian to test the wiring.
Oct 20, 2006 | Hampton Bay 04379 Madison Avenue Ceiling...
Hampton Bay 24002 Ceiling Fan Logo
1,078 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
