If you've recently dropped the camera you may have damaged the lens tube (housing) or jarred the zoom mechanism off of its track. Either problem requires professional repair. If the camera hasn't been dropped, your problem may be due to weak/worn out batteries or corrosion on the
battery contacts inside the camera
which can prevent the full power of the batteries from flowing into the
camera. Try this free fix before you do anything else: remove the
batteries and wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen
into the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera. This cleaning clears
the problem about 90% of the time. If it doesn't work for you, your
batteries may need to be replaced, or the camera may have
a problem that requires professional repair.
Was this helpful?
Yes
No
Popular Solutions for Canon PowerShot S2 IS Digital
I am getting a lens error and then its says to restart camera..The lens is out and will not go back...
(More)
I am getting a lens error and then its says to restart camera..The lens is out and will not go back in..how do I fix this.. This camera is a powershot a470
My S2 IS worked great for several years. Recently the audio playback distorts whenever I shoot...
(More)
My S2 IS worked great for several years. Recently the audio playback distorts whenever I shoot video. Volume levels are set to minimal but the results still distort. Any ideas?
