Neovia, Neo-3775ND 37inch tv
When powered up, the set is stuck, in standby or sleep mode.
Led indicator is showing amber constantly.No picture or sound,
  • DANNII1986 Jan 26, 2008
    WHEN POWERED UP IT IS STUCK AND WILL NOT SWITCH ON JUST KEEPS FLASHING AMBER LIGHT ALL THE TIME
  • ba5hir83 Nov 09, 2008
    powere / standbye keep flashing
3 Suggested Answers
SOURCE: Stuck on standby
Neovia Neo-3775: Standby Led permanently on amber when powered up with no screen or sound. Does not respond to remote or to TV controls.My problem is same as Ed's posted in 2009 - any ideas?
Posted on Oct 30, 2010
walesarumi
  • 6993 Answers
SOURCE: Neovia Neo-3775: Standby Led permanently
your TV is having a power problem. The power supply board is defective that's why the TV won't power up. Its receiving power but it cannot transfer the current to the necessary part of the TV because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the TV might not come on.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
I wish you good luck.
Posted on Oct 31, 2010
How do I stop tv going on standby
hi Shaun.
How do I get my TV out of standby mode? Press the power button once. If the TV does not turn on, observe the LED indicator, usually located on the TV's lower front panel. If the LED indicator turned off after you pressed the power button once, it is in standby mode. Press the power button once again to exit standby and turn on the TV.31 Mar 2015
How to Troubleshoot a TV in Standby ' Techwalla.com
https://www.techwalla.com/articles/how-to-troubleshoot-a-tv-in-standby Search for: How do I get my TV out of standby mode?
How do stop tv going on standby Google Search
Nov 26, 2017 | Televison & Video
Proscan LED TV Will power up the red standby light & standby on amber when turned on but does not show picture or sound unless I unplug and replug over
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 14, 2016 | Proscan Televison & Video
Need help troubleshooting TV
You need to check your inputs. Make sure your tv is set to the same input that you are plugged into. Ex. If you are plugged into HDMI 1 then your TV SOURCE needs to be on HDMI 1.
Dec 30, 2015 | Vizio 37inch VO37LFHDTV1A FULL HD 1080P...
Why wont my techwod l.c.d 37inch t,v wont switch n from standby
Go to the sitting chaik the Sleeptime and reset all setting other wise sleep mode chaik
Aug 31, 2014 | Televison & Video
Stuck on amber light will not turn on
An amber light normally means that there is no signal getting to the screen, if it was stuck in standby then the LED would be red.
Please check your connections to cure the fault
May 31, 2010 | Harsper HP-4200B 42 in. Plasma Television
Amber colored power light on eMachine W3503
The amber power light indicates that your computer has been "sleeping" or "hibernating" and usually all it takes to restart the computer is tapping a key on the keyboard. If this is not the case, try holding the Power switch down for 6-10 seconds to force the system off. Restart in Safe Mode and try to find the settings for Sleep/hibernate, open the control panel and open the Screen Saver. Select "Change Power Settings" and set it for "Never" on sleep and hybernate.
Nov 10, 2009 | E-Machines W3503 PC Desktop
Stuck on standby
Jun 22, 2009 | Philips TP2785C 27" TV
Thomson DTI6300-16, The amber light constantly flashes, no red or amber lights appear! any help/advise would be welcome
Does your Thomson DTi6300 fail to power on normally and displays a solid amber light? During the past few days we have been made aware of an issue affecting a number of our customers with a Thomson DTi6300 box. Customers have been experiencing problems with their box failing to come out of standby mode and typically showing a constant amber light on the front panel.
This fault is due to a broadcast issue which  has led to a corrupt file being loaded onto the hard disk.
Only Thomson DTi6300 boxes have been affected. If you have been experiencing problems of this nature first of all try switching your box off at the wall and leave for twenty seconds. If this does not work, please try the following procedure.
Please note this will unfortunately cause recordings in your programme library to be lost which we?re very sorry about. You may have to try this procedure a few times in order to resolve the issue as it requires complete attention and precise timing.
1.       Disconnect the power supply from the unit by removing the power cable from the back of the box.
2.       Wait 20 seconds and then put the power cable back in while pressing the 'standby/power on' buttonrepeatedly on the front panel of the box.
3.       Release the standby button as soon as you see a light flash on the front of your box and thenimmediately press the arrow buttons on the front panel quickly and in the following sequence:  Up, Down, Left, Right (please note this is not the order the arrow buttons appear on the box).
4.       Your box should then show the amber light with the green light flashing until the disk re-format has been completed which will take around 60 seconds. The box should return to a solid red light (standby) automatically. If after 2 minutes your box still does not display a solid red light, please repeat steps 1-4.
5.       When you return to the TV GUIDE screen, you will now need to scan for channels to restore your Top Up TV channel logos. To do this, please select Option 4 (set-up) from the Main Menu, followed by option 1 (scan for channels).
6.       IMPORTANT: Once you have completed your channel scan, you will need to select option 5 from the Main Menu (Choose your channels) to re-select all those channel providers you would like Top Up TV to download shows from.
We?re really sorry if you have been affected by this issue and greatly regret any inconvenience this may have caused.
May 04, 2009 | Televison & Video
Monitor stuck in sleep mode
It will do this when it's not getting a video signal from the computer. Make sure that the signal cable is firmly plugged in at both ends. Also verify that the computer is actually starting up. The monitor may not be getting a signal because the computer isn't sending any.
Sep 25, 2008 | Compaq TFT5015 15" LCD Monitor
Mogen tv remote control code
can you please assist us with a Sky setup code for Neovia neo-3775nd.
Jan 05, 2008 | Televison & Video
Televison & Video Logo
324 people viewed this question
Top Televison & Video Experts
