Runs ?? I guess you mean the light comes on and it rotates ??
Make sure its is on high cook mode ( in case someone has it on defrost etc) Try it with a half glass of water - if it does not boil, chances are your microwave unit inside the case has died - not uncommon fault and not worth getting fixed as the replacement part + labor is more than the cost of buying a new one.
Was this helpful?
Yes
No
Popular Solutions for GE JE2160 1150 Watts Microwave
my microwave just stopped working. it would stop during cooking and then work again after a few...
(More)
my microwave just stopped working. it would stop during cooking and then work again after a few minutes. Now it has stopped completely. It is dead and only 3 years old
The JE2160 stopped cooking midstream but the timer kept counting down. So, the clock and buttons...
(More)
The JE2160 stopped cooking midstream but the timer kept counting down. So, the clock and buttons work but nothing happens inside, including no light. When I press start, it clicks as if to start cooking but nothing happens. It is a built in microwave that is almost 2 years old. Thanks!
ge je2160 microwave, 2 years old, just died. Replaced the fuse with a 20A/250V time delay fuse and...
(More)
ge je2160 microwave, 2 years old, just died. Replaced the fuse with a 20A/250V time delay fuse and lights turned on. However, when door was opened, fuse blew again. Called a GE authorized appliance service center and they believe the door switch is bad and that the safety switch should also be replaced. How can I be sure its the door switch (as it initially went dead without the door being opened)and how can I replace the door switch and safety switch myself. Thanks.
