First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
Second Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
As you said me your using Nokia 5800 you just need to remove your memory card from your mobile phone after that you can switch on you are mobile.If you still face the same problem means you can visit to your nearest nokia service center so that they will fix your problem with in a few minutes.Thanks for your question happy to help.
nokia 5800 green white red keys not
working
please help
me 5800 ........ touch screen & buttons( green, white & red ) keys
are not working ........ already changed keypad ic and key pad .... but
showing same problem.......any body can help me please send me reply ASAP......
i have purchased a nokia 5800 from korea. now i want to use this nokia 5800 mobile in the phillipines. but is not a working. how to work in the philiipines
Hi! Use an usb data cble to update your phone`s software (you can download the aplication from www.nokia.com). If this doesn`t solve your problem, you have to go to a service and reinstall your software.
