Question about RCA F36683ET 36" TV
Just quit working
The TV was on and just quit working. It started clicking from inside and will not turn on. Now when I try to turn it on, it just clicks 3 times and stops. Is it worth trying to repair?
  • rinchko Aug 18, 2008
    Tv will turn on but will turn off within 3-4 seconds.
    Unpluged set for several hours but no help.
  • adcme Aug 26, 2008
    Also have the popping sound. Removed the back case and found the popping noise and flash is coming from area between the circuit board and screen. (It looks like a tube)
  • 28 Answers
The Flyback transformer has shorted out. A replacement is about $85 plus labor to install it.
Posted on Mar 01, 2010
6ya staff
SOURCE:
Samsung PN58c590 plasma tv
Short circuited component/s at its main board. These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating, to many popular brand TVs and other devices.Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Feb 24, 2014 | Samsung PN58C590 TV
I have an Onkyo TS-DS939 receiver which worked for quit a while and then would not put out any sound when turned on. I would switch from TV to radio sources and after maybe 20 minutes it would start to...
Since the unit eventually works as expected, I would first look for poor solder connections inside the unit. It is quite possible that hte prolonged storage has damaged a few connections. If you can solder, try looking at the solder connections and resolder any that appear grainy or have rings. Update this if that does not resolve the problem and we'll look further.
Thanks,
Dan
Jun 12, 2010 | Onkyo Audio Players & Recorders
When the set is turned on there is a clicking sound then it dies
I am assuming this is an old CRT TV.
In CRT TV's the tube needs quite a high voltage around 30,000 volts. This is generated in the set. When you turn the TV on it is possible you hear the high voltage arcking. This happens if there is dust and dampness. You may see specs of light on the screen when this happens. You could try cleaning the inside.
Nov 24, 2009 | Sharp 27U-S60 27" TV
Clicking from inside the TV. sounds like its going to explode.
That is one or more of the capacitors shorting and discharging. Turn the TV off and take it in to be repaired. If you let it continue to do this it will eventually destory the television.
Doyle
Apr 03, 2009 | GE 25GT240 25" TV
Turn signals have quit working
Many times the turning signals will quit because a bulb has gone out. Have the bulbs checked first.
Nov 05, 2008 | 1998 Ford Explorer
2006 toyota corolla
Remove the starter & inspect the contacts inside the starter solenoid housing. If they are burnt and/or worn, you will get this condition. Replace the contacts and the plunger, or replace the starter. I change contacts in my shop 3-4 times a week. Quite a common failure. The clicking noise is the plunger hitting one contact, but not the other, due to wear.
Aug 23, 2008 | 2006 Toyota Corolla
Clicking noise when turning on the tv. Everything works but the clicking.
When you turn your tv off turn it off using the remote control then turn off the tvs switch itself... Try this for a few days hope it works for you.
Thanks.
Jun 22, 2008 | Akai PT5492S 54" Rear Projection...
TV Will Not Turn On
Good Day;
If you don't hear the relay click suspect Q003. No power suspect Q912, Q914 & I901. Good Luck, big IRISH.
Sep 19, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Samsung txe2745 just quit working -- has an internal "clicking" like a relay trying to close
First of all greetings from Belize mike your set is an old set but you can still get some life out of it please be inform that going into a tv could cause you self injury if you are not qualified to handle an electronics set.the problem with your set is in the power supply there is a 10mf cap situated in the power supply just close a transistor replace it along with power requlator and associated diodes.that will solve your problem.but make checks in the power supply.if you cannot do it yourself take the set to tech.good luck.
Nov 21, 2006 | Samsung TXE2745 TV
Televison & Video Logo
59 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
