Air Compressors
Problem for Craftsman Air Compressors
Generic problem for all Craftsman Air Compressors
Hi, my air compressor runs but is not fil...
By motoridert on Nov 07, 2009
hi, my air compressor runs but is not filling the tank with air?
Comments:
Nov 07, 2009
- Thanks, drain plug is tight. I do hear some hissing but not from that area. It was running fine, I heard a pop and lost pressure and now the tank doesn't fill. Seems like perhaps a hose or connection in the housing came off. Can't seem to figure out how to get the plastic cowling off. Thanks again.
Nov 07, 2009
Clarification Request
Posted by JR in SC on Nov 07, 2009
Do you hear hissing anywhere? If so there's you problem (possible the drain on the tank bottom?) Otherwise your piston is likely worn. I don;t know what you're using this for. For the average Joe there are a number of high-quality low-cost compressors out there for <$100 (harbor freight). Look for a high HP/GAL ration 2hp - 5gal is ideal. Pancake compressors are nice and portable but lack the volume for higher-demand air tools. I prefer cast-iron 'oil' ones for longevity.
Solution #1
posted on Nov 08, 2009
Not Rated)
buffalonyman
Rank: Guru
Rating: 85%, 743 votes
If you do not hear the air escaping from a joint, then perhaps the piston is broken. You'll have to disassemble it and examine the compressor components
Was this helpful?
Yes
No
Popular Solutions for Air Compressors
Questions and Unsolved Problems for Air Compressors
Answer
compressor has no oil pressure but seems to be running good
Answer
looking for a user or owners manual for a puma pku5508g gas air compressor
Answer
DK697100AV 2-gallon air compressor. Doesn't turn on at all. I opened it up and found a burnt fuse. I... (More)
Answer
my air compressor dose something the same when i took it up i have my 3/8 hose going to my tank and... (More)
Answer
it is a small 2hp 3gal compressor whenever i plug it up the switch just humms and then it throws the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Compressor Experts
Top Garden & Power Tool Repairmen
in , CO
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
