Question about Maytag PAV2300 Top Load Washer
Trouble removing the seal nut and the long screw that hold that bottom agitator
Help... I have a Maytag PAV2300, I'm trying to remove the seal nut and bolt that held the circular agitator at the bottom of the tub. Problem: I don't have that spanner wrench(35-2968) or the seal tool (22002898). Is there another way to remove the seal nut and the bolt without these tools, without me damaging anything so that I can replace the triple lip seal ring.
Thanks in advance,
NoviceLady
vds100100@yahoo.com
  • 1 more comment
  • novicelady Jan 08, 2008
    "Wagnut",
    Thank you!!! ,10 hours later, 3 trips to the hardware store and 14 bruises on my arms, I finally ended up chiseling the plastic seal nut out. It took me a while because I have a bad right elbow, so I had to work in shifts. For us novices, I would suggest the more details you can provide us knuckles out here the better. I finally got everything taken out of the washing machine. Now the only problem I have, is getting the other part out so I can replace the metal seal rings. Besides having the strength of Hercules, can anyone tell me how to pull apart the bottom and the top(I have removed all the screws) so I can swap out the triple seal rings. The seal nut is no problem.
    Thanks again,
    NoviceLady
    Watugot, I apologize for incorrectly spelling your name. Thanks again!!!!
    Watugot, my email is vds100100@yahoo.com. I got a manual but it is not clear on how to open the casing that houses the long bolt. The housing at the top appears to connected with some type of rubbery gluem and the bottom portion I removed all 6 screws but I can't seem to pull it apart. :- O
  • 290 Answers
If your machine has the plastic nut, I use a pair of channel lock pliers to remove it. It usually will break but you will need to replace it any way. To get the basket support off, I use a piece of flat steel and large hammer. This will need to be replaced also. The new basket support has a seal in it that takes the place of the plastic nut.
I assume you are replacing the bearing and seal since the bearing wearing is usually what causes the seal to leak.
Post back if you have any questions.
Thanks/Mike
Posted on Jan 05, 2008
  • 1 more comment
  • Michael  Lindley
    Michael Lindley Jan 05, 2008
    I have had several machines that I had to use a chisel to cut the plastic nut and the aluminum basket hub off because of years of detergent buildup have caused the threads to sieze to each other. If you have to do this, be very careful not to damage the threads on the transmission housing.
    Thanks/Mike
  • Michael  Lindley
    Michael Lindley Jan 08, 2008
    If you have taken the basket out and the seal nut off, you now have to remove the basket hub. This is the latge aluminum hub that the basket was bolted to. This is what the spanner wrench is for. I use a piece of flat steel 18" long, 2" wide and 1/2" thick and a large hammer. Screw a bolt back into one of the holes so that it doesn't collapse, place the edge of the steel against the shoulder of the hub and hit it with the hammer. The hub is threaded to the transmission housing and the seal goes under it. Getting this piece off is the moment of truth as to whether the washer is worth saving. If the hub and transmisssion are siezed together so bad that the threads on the transmission can not be saved, it is more economical to replace the washer than try to repair it.
    Do you have a repair manual? Since you knew the numbers for the tools, I thought you might have one. If not, post me an email address and I have one on PDF I will send you.
    Thanks/Mike
  • Michael  Lindley
    I hope you ecieved the manual ok. I was running late this morning and unable to follow up with you.
    I am not sure what you mean by the "long bolt". If you are talking about the splined shaft that the agitator was on, it is the agitator shaft of the transmission and the rubbery seal around it is part of the transmission also. Nothing that sticks up through the center of the basket comes out. The 6 bolts hold the basket to the basket hub. The basket comes out, then you remove the seal nut and the basket hub. The hub screws down on the transmission housing like a large nut.
    I got my tool out that I use to remove the hubs with, it is only 5/16" thick instead of 1/2" as I told you.
    Thanks/Mike
  • 790 Answers
Hello !!!
Atleat do u have any pliers ???
2 Suggested Answers
  • 90 Answers
SOURCE: Maytag PAV2300
My opinion is no. You need those tools for reinstalling so you dont break the parts you are installing
Remove dual agitator
The agitator in your Maytag Dependable Care washer uses a back-and-forth motion to move your clothes from the top of the washtub to the bottom and back to the top again. The fins on the side of the agitator help facilitate this movement. When one of the fins sustains damage or the agitator fails to move, you must remove the agitator to make the necessary repairs.Disconnect your Maytag Dependable Care washer from the electrical wall outlet. Turn off the valves supplying water to the appliance.
2 Open the washer's lid to access the agitator. Look for a 1/4-inch hex screw recessed in an opening about three-quarters down the side of the agitator.
3 Insert a 1/4-inch nut driver into the opening in the side of the agitator. Fit the nut driver over the head of the screw. Turn the screw counterclockwise to remove it.Grab the bottom of the agitator with both hands. Pull the agitator from the bottom of the washtub.
  • Nut driver, 1/4-inch
Sep 29, 2016 | Washing Machines
Elite model #11027087603. How do I remove tubseal nut on bottom of washer that holds motor rotor on shaft?
that should have an inset, hex-headed screw/bolt. You will have to hold the rotor with one hand and use your other hand to loosen that screw. they use thread lock on that screw, so it will be difficult. but, that's only half the battle. You will have to remove the tub cover, agitator (7/16 agitator nut size), and the spin basket to access the tub seal. the seal has to go on from the inside of the tub assembly. Make sure you don't use anything against the outer lip of where the seal seats inside the tub, or you will have to replace the outer tub because it will still leak. Push the seal all the way down. then before you put everything back together, pour a small amount of water in the tub and see if you see any leaks. anything major will show then, but if there is a small leak, you will not know it till you try to wash with it. You shouldn't have to remove the stator screw or do anything from the bottom side of this unit. You should be able to replace that seal from the top side. good luck.
Nov 28, 2015 | Kenmore Washing Machines
When the washer goes unto spin cycle, it makes a loud roaring noise and is leaking from the bottom
It sounds like the tub seal is leaking, allowing water to leak out of the tub and damage the drum bearing. Unfortunately you need specialized tools to replace the seal and bearing, so you may have to get a maytag service agent in to look at it. If you're handy with a welder you may be able to make up a tool yourself, it basically consists of a flat hexagon with tabs on the inside to fit the drum nut, and some handles on it. You'll need to remove the front panel and top panel. Then remove the cap around the top of the tub. The agitator is held on by a small screw near the base of the agitator, loosening it will allow you to remove it. Now you can see the tub nut, this is reverse threaded, so it's loosened clockwise. Then you can lift out the drum. Next on the shaft is the top part of the mechanical seal. Remove the grub screw out the side. Now you'll need the same tool you used for the tub nut to undo the seal, rotating in the same direction. Remove the outer tub by undoing the 3 bolts that fix it to the stays, and disconnect the level tube and drain hose. From here you should have printed instructions that come with the new parts to replace the seal and bearing. Please feel free to get back to me if you have any further questions.
Jul 28, 2011 | Maytag Washing Machines
How do we remove the tub seal assembly on a mat12cs commercial Maytag?
This is a not a job for the back yard mechanic. There are many things that need to be done carefully. There are 3 letters missing from your model number also... However the procedure is pretty much the same for all models.
NOTE you will need a special tool to remove the stem seal. Unless you have the special tool in hand don't even bother starting the job. Tell any appliance part center you need the tool for removing an Old style Maytag tub nut and stem seal.
1. Remove the front panel
2. Remove the cabinet top / lid by removing the 2 screws in the top front corner of the cabinet. and rotate the top up 90 deg. Be careful of the lid that will swing freely.
3. Disconnect the pump inlet hose from the bottom of the tub.
4. Disconnect the water injector hose from the tub cover.
5. Remove the tub cover
6. Locate the only hex head screw in the side of the agitator and remove it.
7. Lift out the agitator
8. Using the special tool you should have in hand by now.... Remove the wash tub nut and stainless steel washer under the tub nut.
9. NOTE the distance of the inner tub from the outer tub and then lift out the wash tub
10. Next is the stem seal. You first have to remove the allen head lock screw in one of the 4 faces of the tub nut. Then again using that same special tool remove the upper part of stem seal. Be careful when lifting it as you can actually damage the grease seal in the very top of the tub seal upper portion. Once the metal upper part of the tub stem seal assy is removed... there another NOTE of caution...
11. The actual tub seal has a carbon face on the top of it and if you crack the carbon seal it your machine will leak all of the time there is water in the unit.
grab the tub seal as the very base of the seal and gently rotate and lift it off the inner tub sealing surface.
12. Install the new stem seal.... by again gripping it on the bottom only and gently rotate and push it down into place until it seats level.
Reassemble in reverse order of disassembly but make sure you INSTALL the allen lock screw into the stem seal nut face. If you don't the stem seal will come loose and your unit will leak again. Final note is during re-assembly make sure the wash tub is centered.... rotate the tub once you tighten the tub nut and make sure it is not to elliptical if you don't get it right... the machine will gyrate with use in the spin cycle.
Jan 14, 2010 | Maytag MAT12CS Top Load Washer
Washer was filling but not aggitating,
remove the dispenser in the top of agit . under it is a bolt. remove bolt. it holds it down . if it won't pull by hand then we use a ( agi tamer. this is a split inner tube type/very flat with a split in it . slide under agit and add water and up it comes . 5 min. .. i don't think something is under the agit I belive the trans is failing . but you need to look . . agit needs to be removed to repl trans anyway ..mm
Dec 12, 2009 | Maytag PAV2300 Top Load Washer
How do I remove the agitator on a Maytag washer?
There should be a screw at 90 degrees to the agitator to remove and release it
Nov 12, 2009 | Maytag PAV2300 Top Load Washer
I can't get the agitator out.
remove fabric softner cup from top of agitator and remove 1/2 bolt for inside agitator then you'll need spanner wrench to remove nut that hold spin basket in tub. maybe use some affresh tabs or washer magic to remove build up
Dec 13, 2008 | Maytag PAV2300 Top Load Washer
Seal leaking from tub. How do I remove agitator?
If this is a Maytag Performa or Atlantis model all you have to do is remove the center cap on the agitator by pulling on it and locate the agitator bolt underneath. Loosen the bolt, and the agitator should pull straight up.
If this is a Maytag Dependable Care series there will be 1/4 inch screw along the side of the agitator towards the bottom. Remove this screw and the agitator will pull straight up.
I hope this helps you.
Aug 11, 2008 | Maytag Washing Machines
Maytag PAV2300
Jan 05, 2008 | Maytag PAV2300 Top Load Washer
Maytag Washer: How to Remove Tub
Under the agitator is a flat nut with notches in it. this nut requires a spanner wrench that will fit into the notches. You can use a large channel lock plier. rotate the nut counter-clockwise. under the nut will be a seal. remove the nut and the seal and pull up on the inner tub. to replace you'll need to replace the seal. if the nut isn't too chopped up, use this to refasten the tub.
Sep 05, 2007 | Washing Machines
Maytag PAV2300 Top Load Washer Logo
424 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
