Good day, With limited information, if one, you are talking about the fresh food side, and two, the machine has water in the door, it may well be the water reservoir tank, behind the crispers or it's fittings are leaking.
As a temporary test, at the rear of the machine is the dual water valve that feeds the ice maker, and the water in the door. There are 2 plastic lines coming out of the water valve. Unscrew the larger one ( have plenty of towels around to collect any backfeed). Leave disconnected for now as long as the valve does not leak water. As well, unplug the two wire plug that feeds that side of the valve. You'll still get ice, but no water in the door. Test for results.
Was this helpful?
Yes
No
Popular Solutions for Whirlpool 25.6 cu. ft.
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with...
model gd5shaxnq00 -inside lights not working. just the filament glows and there's a buzzing noise....
(More)
MODEL GD5SHAXNQ00 -INSIDE LIGHTS NOT WORKING. JUST THE FILAMENT GLOWS AND THERE'S A BUZZING NOISE. TEMP INSIDE SEEMS OK
Whirlpool side-by-side freezer side is making an intermittent ticking noise and items inside are...
(More)
Whirlpool side-by-side freezer side is making an intermittent ticking noise and items inside are defrosting rapidly...ice cream melting...Seems 'frig side isn't as cool as it should be as well--what do you think?
Ge side by side refrigirator- freezer. Refridgirtor will freeze a drink in bottom drawer top shelf...
(More)
Ge side by side refrigirator- freezer. Refridgirtor will freeze a drink in bottom drawer top shelf items are warm.. Freezer the same all on bottom is frozzen but will not make ice on top shelf?
