Problem: I have a 1987 Ford Ranger 2.3L, Fuel Inj., 5 spd. About 6 months ago, the intermittent problem started. While driving, the engine just dies. Bam!! I can immediately restart it by cranking it. Or sometimes it restarts about 1-3 second after it quits.
I check the ECC error codes and got a 14 (PIP problem) and an 18.
Dan E. West <pines @mindspring.com> wrote in article <33fa52f5.3335 @news.mindspring.com>... I would check the fuel inertia switch, it is located in the passenger footwell behind the carpet. Before pushing the reset button in, start the engine and give it a tap on the housing with your palm and see if the engine dies. This could also explain your ignition related trouble codes, as it will cut all signals to the ignition. Simple, but worth a try. -- Warren Kurtz Ford Ranger Fans On-Line http://www.sky.net/~wkurtz/ran ger.html
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on 1987 Ranger Problem:
Solution #2
posted on Aug 09, 2005
Kim1 - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
The inertia switch does NOT cut the PIP signal!!!
All it does is open the fuel pump circuit. The code 14 is a real big clue to your problem. You have either a wiring problem or an ignition module problem.
The inertia switch is not the problem with this truck.
Mark
