Sharp -COPIERS - AR-5316 Advanced Digital Imager Copier
Sharp copier ar-5316
posted by ibidun on Jan 05, 2008
please how do you change the drum of the copier ar-5316.including the developer.And apart from the developer what else do u need for changing a drum inthe copier
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 14, 2008
FixYa! (100)
kamalaldurra
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
sharp fo-2600 fax ld error
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on sharp copier ar-5316:
I don't want to Accept this solution
Best Solution
posted on Mar 06, 2008
Helpful (85)
nobo2008
Rating: 85%, 1 votes
e7-11
Thank You!
Best Solution
posted on Jan 06, 2008
Helpful (85)
sir fixalot
Rank:Guru Guru
Rating: 91%, 139 votes
That unit uses an AR-016TD Toner/Developer Cartridge. The developer is changed each time you replace the toner. To remove the drum unit open the right side cover, then the front cover, remove the TD cartridge, loosen the green screw on the front of the developer unit housing just above the TD slot. carefully remove the DV unit without tipping or you will spill out the existing DV. Then you can pull out the drum unit. There may be a green screw on the drum that must be loosened but I don't think so on that particular model. Installation is the reverse of removal.
Rating Locked! (?) ibidun has rated this solution as Helpful
Thank You!
Solution #4
posted on Oct 30, 2008
Not Rated (0)
franki256
Rating: 0%, 0 votes
My copier reports H4. Please give me the solution to this problem.
Thank You!
Solution #5
posted on Mar 10, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
wat iz error code H4-00 sharp AR -M 236
Thank You!
Solution #6
posted on Mar 05, 2008
Not Rated (0)
Sadat
Rating: 0%, 0 votes
i have a problem with Sharp AR-5316E, the problem is coding problem it is showing that H and 4
Thank You!
Can you Help with these Copiers problems?
Sharp -COPIERS - AR-5316 Advanced Digital...
help
computer problems
I've got used AR651 recently. When I turned on machine...
que debo hacer, no tengo el manual de servicios y me pide...
I have sc code 329 on richo aficio 2032e
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
