Question about Maytag 24 in. DWC7602 Free-standing Dishwasher
Connecting to faucet
I received a used dishwasher. I've never used one before and am not sure how it hooks onto the faucet. I have tried several things. I am not sure that I have the parts that are needed. Is there a place that I could look at the connecters to see if I have what I need on mine?
  • sniickers Jan 05, 2008
    Found out that I need an adapter for the faucet. Hope this help someone else. Thanks
Well ther is in the back you will see a round button try that or just go back to the store and have them fix it for you and when you will like to talk to me my e-mail is alizebass@inbox.com
Posted on Jan 05, 2008
Low water pressure from wand
The pressure in a watering wand extension to a garden hose is related to the water pressure from the hose itself.
The point of a watering wand is to provide a gentle and widespread flow of water. If you are looking for a powerful stream, then a different type of attachment is required.
Check to make sure that there is no leaking at the faucet, or at any connecting point. Leaks will lower water pressure at the end point.
Check to be sure the wand itself is free of dirts and clogs. If the wand is dirty or blocked, it will affect the pressure.
If there are several hoses hooked together, the water pressure is more likely to be low at the last point, the wand itself.
When the water pressure drops as a result of another use, like a shower, dishwasher, another hose faucet, then the water pressure will drop in the wand.
Aug 06, 2017 | Water Garden
GE portable dishwasher connector hose slips off faucet adapter
Google your dishwasher you will see parts on line There are loads just looked .
Apr 13, 2017 | Dishwashers
Connecting dishwasher hose
Try soaking the hose in a bucket of hot water for a few minutes ,then twist it anti-clock wise so you have enough turns to screw it onto the water hook up.
Feb 23, 2013 | KitchenAid Kitchen Aid Superba Series...
I've hooked up my danby to the faucet but the water leaks out the top how do i fix this?
You need to have the RIGHT couplings so that the inlet is secured correctly to maintain the right water pressure to the washer. A visit to the hardware shop, plumbing section could help a lot to get the right choice of coupling to mate the hose from the outlet to the machine. You can use teflon if the thread is too loose and makes a leak.
Dec 31, 2012 | Danby Dishwashers
Trying to connect Culligan drinking water filter to my faucet, BUT, the treads on the faucet are too high for adapters to reach. How can I connect? Also adapters aren't long enough to reach threads....
One thing to try is pick up a tap adapter, from an appliance store. The adapter is intended to connect a portable dishwasher or washing machine....these adapters have several small pieces that may be able to be used with the pieces from the Culligan adapter.
May 01, 2011 | Culligan Home
Is there a filter that needs to be replaced or cleaned? After cycle is finished there is still water in the bottom. If I run cancel several times, it pumps it out but very slowly.
If your dishwasher is connected to a disposal and it is clogged the dishwasher will not
pump out. Also if it has an "Air Gap", this may have debris in it. It looks like a small chrome
cap next to the kitchen faucet. You can dismantle it to clean it or just replace it. Just be
sure to hook the inlet and outlet hoses up correctly. Hope this solves the problem.
Mar 14, 2011 | KitchenAid 24 in. KUDM25SH Built-in...
Water leak at hook-up
Should be rubber washer inside hose if its one that screws onto faucet or an o-ring
Jan 25, 2010 | GE Nautilus 24" Built-in Dishwasher
Faucet solution for hooking up portable dishwasher
there is a generic adaptor that fits on your faucet; take the name, model# and, hose to a hardware store and, they can show you the right adaptor for your machine
Sep 15, 2009 | Dishwashers
How to hook up detached dishwasher to faucet?
Hello there:
you are going to want to make sure that the threads on the hose match the faucet and also make sure that the gasket is in place you might even need to get a adapter for the unit to hook up to the faucet.
i would consult the manufacture or the users guide for further help
Aug 08, 2009 | Danby DDW1805W Designer Series...
Dishwashers Logo
137 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
