Question about Sharp Aquos LC-PD50U 50 in. Plasma Television
Sharp LC-PD50U No power
I am writing about a 50 inch Sharp plasma television from around the year 2000.  Generally there is a red light glowing even when the television is off but this is no longer the case and it will not turn on.  My first thought is maybe it's the power supply but I really have no idea.  This is a nice, yet older tv and I'm wondering if it's worth fixing; I think a repair center might cost anywhere from $150 to $300 in labor plus parts maybe around $500 all said and done?
Thanks!
  • jsmith8226 Jul 18, 2008
    I TURN THE T.V. ON AND THE GREEN LIGHT IN THE FRONT COMES ON, AND THE RED LIGHT IS ON IN THE BACK OF THE T.V., BUT NO PICTURE OR SOUND COMES ON. (SHARP/LC-PD50U)
  • Ian Dempsey
    Ian Dempsey Nov 29, 2012
    replace power supply
I have just had this same problem. Did it tuurn out to be a power supply or the fuse?
THank you,
ALan
Posted on Aug 10, 2008
SOURCE:
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Luminous
Please provide the model and make details
Apr 08, 2008 | Sharp Aquos LC-PD50U 50 in. Plasma...
We are trying to set up wii-through the dvr to play on Sharp LC-PD50U-unable to get it to work.
Connect the Wii directly to the TV either using the HDMI cable or the Hi def cable(5 RCA connectors) that come with the Wii. Then select the input number on the TV to get a picture .
Dec 25, 2012 | Sharp Aquos LC-PD50U 50 in. Plasma...
No Power
You will have to remove the back cover to get to the fuse. Just follow the power cord/power jack and it will lead you to the fuse. The fuse will be located on the power supply board. If the fuse is blown, you could be dealing with a short circuit in the set.
Sep 10, 2012 | Sharp Aquos LC-PD50U 50 in. Plasma...
Wii remote hit the screen and tv picture will not work? Are the fixable?
Not likely. The screen is the most expensive part of the TV. It CAN be replaced but a new TV will probably be cheaper.
Dec 25, 2010 | Sharp Aquos LC-PD50U 50 in. Plasma...
Sharp flat screen no sound after moving it from downstairs to up
Try the main resets in the back by the a/v in and out jacks. If this does not work, call Sharp Customer Service and tell them that you already did the resets. There is a known problem with a heat dissipation pad for the onboard speakers and they will send a repair tech to replace the pad for free, even if you are out of warranty. At least that was the case with my LC-32D6U. My understanding is that a surround sound system would bypass the problematic part of the sound board which is why yours worked in your basement.
Mar 09, 2009 | Sharp Aquos LC-PD50U 50 in. Plasma...
LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
May 08, 2008 | Sharp Aquos LC-PD50U 50 in. Plasma...
Sharp AQUOS LC-52D62U LCD TV
Sharp lcd screens are very easly damaged especially the larger screens,this could be at fault even though it looks ok,try shinning a light on the screen and checking every inch,could be the internal screen that has damage hence why not powering up.
Failing that it sounds like an internal short.
Apr 20, 2008 | Televison & Video
No power
It could be a fuse and be aware the fuse is on the power supply. It most likely is a failed power supply.
Jan 04, 2008 | Sharp Aquos LC-PD50U 50 in. Plasma...
Sharp Aquos LC-PD50U 50 in. Plasma Television Logo
184 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
