Question about Acer Aspire 5610-4648 Notebook
Hi i want to unlock my laptop to any region, can you help
Pioneer dvd-rw dvr-k17rs ata device - this is the model on my acer aspire 5610 laptop
  • Anonymous May 12, 2008
    my acer aspire 5610 notebook suddenly developed a problem with the operating problem and in effort to reinstall windows, it is asking for a bio password and there is none, i bought the system brand new and no bio password was given. How can I overcome the problem, any help will be highly appreciated.
My laptop ibm is new and when i start it,it show code
Posted on Sep 01, 2008
PC DVD drives can have the region code changed 5 times only.
Whatever region you set it to on the last available change will be the units permanent region from then on!!!
Any hardware modification to the unit to 'unlock' it is a violation of many countries laws and absolutely unlawful in the U.S..
The region codes are there to protect the copyrights of the media producers and ensure the units proper operation with inserted media.
Posted on Jan 05, 2008
Pioneer DVD-RW DVR-K17RS ATA DEVICE NOT WORKING L CAN OPEN MY CD FILES my device cannot read cd but work with dvd
first you need to re install the driver,
do this and try again, if not solved you need to fix the registry, but this can harm your computer,
download tune up utilities and ccleaner,
those programs can help you
Apr 26, 2009 | Acer Aspire 5050-3242 Notebook
Pioneer DVR-K17RS ATA ACER CODE=39
Code 39 for cd/dvd drives is a common problem, you need to edit the registry to fix this error. See these instructions on how to fix code 39.
Mar 28, 2009 | Acer Aspire 5610-4648 Notebook
it's windows issue, you just need to edit windows registry.
Follow this step from microsoft:
http://support.microsoft.com/kb/314060
Jul 01, 2008 | Acer Aspire 5610-4648 Notebook
Hi How old is this laptop? If it is brand new, then you should be able to send it back to acer. Its the problem with drive or mainboard not with the drivers.
Thanks
Mar 16, 2008 | Acer Aspire 5610-4648 Notebook
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Feb 22, 2008 | Acer Aspire 5630 Notebook
i believe it's software problem, you can reload the operating system using alt+f10 or you can try this
Feb 16, 2008 | Acer Aspire 5610-4648 Notebook
Try to remove the device from Device manager, and then reinstall or upgrade the driver. If the error continues to occur, it may be possible to edit the operating system Registry to resolve the issue.
Click the Start button, press run and type regedit.
  1. In the Registry Editor window, in the left pane, double-click the HKEY_LOCAL_MACHINE folder.
  2. In the HKEY_LOCAL_MACHINE folder, double-click the System folder.
  3. In the System folder, double-click the CurrentControlSet folder.
  4. In the CurrentControlSet folder, double-click the Control folder.
  5. In the Control folder, double-click the Class folder.
  6. In the Class folder, click to select the {4D36E965-E325-11CE-BFC1-08002BE10318} folder.
  7. In the right pane, click to select the UpperFilters registry value.
  8. Press Del / Delete to remove the registery entry.
  9. In the Confirm Value Delete dialog box, click the Yes button.
  10. In the right pane, click to select the LowerFilters registry value.
  11. Press Del / Delete to remove the registery entry.
  12. In the Confirm Value Delete dialog box, click the Yes button.
  13. close the regedit window.
  14. Restart the computer.
Feb 11, 2008 | Acer Aspire 5100 Notebook
If you can't restored the driver, you should reload the operating system using Alt+F10 or using disks (not from windows, boot from disks)
In your case, it's look like you can't access the dvd in windows, i hope you can access in dos mode.
Jan 20, 2008 | Acer Aspire 3680 Laptop
Dvd-rw dvr-k17rs ata with aspire 5610z
Hey Google AUTORUNGUI.dll Download It And Then Just Copy The .dll to Your Win System32 Folder Replace It.
SHOULD WORK...........................................
Comment If It Doesnt I Will Tell You Some More Solutions
And Leave Your PC Info With Operating System OtherWise Really Hard ....................................................................................
Jan 08, 2008 | Pioneer Slim 4x ATAPI (DVRK12RA)...
Acer Aspire 5610-4648 Notebook Logo
170 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
